Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Oil change -> Oil leak problem
  1. #11
    Ryan
    qld
    brisbane
    Aust.
    i had the same problem ages ago, i used a washer that was pretty hard. so all i did is got the a rubber washer beside me... slowly undid the sump bolt, then jammed my finger there. then i got my sister to change the washer and i put it back in.
    you will either get your arm covered in oil (loose like 200ml) or you will have to drain it entirely.
  2. #12
    E-Famous (Remeber your roots)
    Yeah, can do that, or drain it into a bottle and put it back in
  3. #13
    Get an organic sump washer, those are the best.
  4. #14
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Hmm, it isn't losing a great deal. Might just drain it when I get back and put it back in. Pretty sure the washer is the right size. Will see when I do it! Thanks for the responses guys.
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
  5. #15
    Keating
    Caboolture
    It's only losing oil when it's parked. At this stage, all I can do is top it up when I have too (doesn't lose much) and I will have to drain and look at it again when I get back. Thinking an aluminium washer this time... *shrugs*
  6. #16
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    try a copper or brass washer
  7. #17
    Keating
    Caboolture
    The GFs father got told that, all he could buy was an aluminium one. Does the job by the sound of it.
  1. oil leak
    By Fozz in forum Technical - Questions
    Last Post: 6th April 2009, 05:56 PM
  2. Serious 4AGE oil leak
    By Golberg in forum Technical - Questions
    Last Post: 21st July 2008, 12:22 AM
  3. Dizzy oil leak
    By wide s13 in forum Technical - Questions
    Last Post: 26th May 2006, 10:02 AM
  4. how to clean oil spill or leak in drive way?
    By johl in forum General Topics (No Technical Questions)
    Last Post: 18th April 2006, 07:50 PM
  5. diesel in your oil change
    By damo46 in forum Technical - Questions
    Last Post: 14th January 2006, 12:48 AM
