Here are the photos as promised. OPEN TO ALL OFFERS![]()
Decided to do a full clean out of the work shop. Heaps of new stuff. CBF posting pictures of all the stuff. Let me know if you want pictures of a specific part.
1.KE70 Drift setup, this includes Front struts with Monroe inserts and cut springs, the struts are complete with LCA, tie rods, castor arms, sway bars ect. The rear consists of KYB Excel G shocks with cut springs and what appears to be an LSD (locked standard diff) only problem with it is that I cut the rubber brake hoses to get it out, and the diff is missing the rear cover. However if you were using the diff to replace your current setup you would already have the necessary parts to install.
2.4AC Cross member, comes with steering rack and long bolts that connect it to the chassis
3.T50 Comes with Shifter, Clutch, slave and flywheel
4.KE70 Hydraulic clutch setup, pretty much a home made attempt at making an AE71 clutch peddle,
5.4A Engine mounts
6.KE70 Tail shaft to suit T50 to standard Diff
7. Random KE70 fuse box
8. A Couple of panhard rods (AE86 and KE70)
9. Brake master for KE70
10. 4ac coil
11. 4ac dizzy
12. 4ac alternator
13. 4age coil and igniter SOLD
14. ke70 washer bottle
15. RHS guard for AE86
16. 20v airbox parts
17. Heaps of struts (some AE86 some KE)
18. 4ac starter motor
19. T series rear tail shaft part
20. AE86 mud guards.
21. Heaps of LCA's
22. Heaps of steering arms.
23. Jap AE86 vented disks and calliper, just re surfaced. (can throw in some calipers and struts)
24. New 86 front shock insert (Exel G)
25. Full bolt in roll cage (home made)
26. T-series (open wheel or locked)
27. AE86 bonnet
28. Spare 4ac fly wheel and clutch.
29. Heaps of interiour bits. (seat belts and KE70 Door cards SOLD, still got heaps of 86 stuff)
30. Heaps of stockish 13's
Condition
1.All components seem to be in good used condition however it’s hard to tell without driving it.
2.Couple of scratches on the crossmember nothing major. Steering racks probably abit worn, boots probably need replacing, nothing major though.
3.Hard to say with out having driven it previous owner said it drove fine.
4.Definatly home made, seemed to work fine, master cylinder looks almost new. Solid line is probably a bit bent.
5.Nothing wrong with them but if I were to re use them id replace the rubber bushes
6.Good/Used
7-29. CBF describing it all let me know if you interesded and ill be happy to sent you pics/ tell you every thing you need to know about it
Price
1.$450
2.$150
3.$250
4.$100
5.$Offers
6.$Offers
7-29. Open to offers ive got a decent idea of what every things worth so no stupid offers please, im not that desperate for cash....
All items are located in adelaide although id be happy to assist with the postage of any items.
Id rather any questions to be directed to me via PM or phone me on0410664946
Christian
you got pmd
Tail shaft is sold
where bouts in adelaide are you located?
hey mate just wondering if you have any door cards all 4 and seatbelts in good condition thanks
Dont Stop High Performance Cars
Ban Low Performance Drivers
2003 BA Fairmont (Turbo Build Currently)
1984 E30 323I Coupe (Pimp Daily)
1983 AE71 (Defected/ Track)
1984 KE70 SOLD
Sorry for the slow reply guys i work pretty long hours,
arrex7: The parts are located in wingfield, but i live in burnside so pickup can be arranged from either.
antman89: Yes i should have a set of seat belts and a set of door cards. You are wost welcome to drop into my workshop at wingfield, or if you PM me your email adress i can sent you some photos![]()
PM'd
whats the address at wingfield i live close by ill drop in tomorrow if thats cool![]()
1984 KE70 SOLD
can you post some pics of the panhard rods for ke70's
you play halo?
add me GT: samnbhnc
