Results 1 to 10 of 16
Thread: whats this engine mount plate do?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default whats this engine mount plate do?
    behold a 4A engine mount:
    nothing new here but I want to know what does the metal cup thingy do on the right? I know where it goes but I dont see the purpose.
    I have made my first test engine mounts to go from a 4age to a ke30 to ke70 and I have allowed for this thing to be in there, have I wasted my time?
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    i always thought it to be a cover for the rubber mount, stop grease and oil deteriorating it?
    AE86 THE BEST
    Endeavour Hills
    yes I was thinking something along those lines
    Veteran driftke70's Avatar
    Ryan
    Buderim
    rubber cuts under pressure, that would be to stop rubber cutting through its movements.
    wheelfriends.wordpress.com
    Endeavour Hills
    How would it do that?
    Jonny any idea how they are different?
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    its also a quick brace for when the rubber breaks to sort of keep it together
    mereki.
    ~KEEP DRIFTING FUN~
    Jonathan
    Another funny observation. The propper 4A-GE plate is a bit different to the 4A-C one.
    Veteran slide86's Avatar
    Huw
    Hills
    shield it from heat maybe?
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    i think it is a heat shield as it is usually on the exhaust side, but it will also act as a small spacer plate to keep the engine level. probably won't make a massive difference running without it, but i don't see the point in throwing it away either
    Andy
    Rob
    Moorabbin
    I don't think Toyota wouldn't go to the extra cost of putting in a spacer there, I reckon they would make the mounts longer if that was the case. ( I could be wrong though)
    I think it is to protect the mounts from oil and dirt etc (rubber doesn't like mineral oil which comes out of the engine pretty regularly)...
    Sam if you have allowed it to stay on there I dont think there will be a problem, if it helps your mounts last a bit longer then that is a good thing.
    Jonny, that's interesting, how are the two plates different?
  1. wtb 4age engine mount t50 mount
    By evil86 in forum Cars or Parts Wanted
    Last Post: 2nd August 2011, 01:11 AM
  2. Sandwich plate/engine end plate info needed 4AGE
    By killar_of_giants in forum Technical - Questions
    Last Post: 11th February 2011, 02:14 PM
  3. Replies: 4
    Last Post: 19th February 2010, 01:30 PM
  4. WTB AE86 Engine Mount + W58 Gearbox Mount
    By Medwin_3sGTE_AE86 in forum Cars or Parts Wanted
    Last Post: 2nd August 2009, 02:51 PM
  5. Oil Cooler and Sandy plate + remote Mount
    By RyGuy86 in forum Car Parts For Sale
    Last Post: 27th August 2007, 01:36 PM
