Results 1 to 9 of 9
Thread: ECU Loom Question (w/pics)
    Eastside
    Default ECU Loom Question (w/pics)
    Car - ae71
    motor - 4ac
    use - daily/streeter
    problem -
    occurs/started when -
    personal situation -
    Hey guys,
    just a quick question, when i got a new 4ac for my car i got a loom out of a ae86 aswell i got it for free so threw it in the shed. looking at it the other day i saw it has 2 wide plugs at the of it, witch looks like it plugs into a ecu. but i'm not sure. there's been some wires added and soldering and fresh tape on it. so are these ecu plugs? and will it fit into a ae71? cheers, Ben. btw it's to run a 16v 4age.
    Some postman, is groving... to all our love letters... some postman is gonna cry! - Some postman you turned out to be..
    Veteran shift_rook's Avatar
    SE Burbs
    don't lok like 4age ecu plugs form memory, one sec
    the second later: nope not ecu, i saw some in my car that looked similar but they weren't plugged into anythin.. come round and have a look if you feel like it haha
    Eastside
    cheers man. yeah the looms been "modified" so there's alot of plugs and crap.
    so there not plugged into anything. wonder what there for? lol. might pop round. or is 10:30 past your bed time haha!
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    They are not ecu plugs.
    I am going on a whim and suggest they plug into the instrument cluster.
    I think on that blue plug I can see a red wire with blue trace, if that is correct and in position 14 on the plug, it would be fed 12v from the 7.5a gauge fuse, also if there is a brown wire at position 3 on the same plug.
    What are the wire colours?
    The little plug with red wire with white stripe I would say is either power feed into the stop light switch, or from the door opening circuit. On the same plug is an earth (White with black stripe)
    Ok
    Seamus
    Milton
    yep, white and blue plugs look like instrument cluster to me
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    from memory (don't quote me) the black wire with red spots is for the tacho
    Andy
    Ok
    Seamus
    Milton
    monster tacho ftw
    Coolangatta
    Get yourself a copy of the electrical wiring diagram, parrot has posted links to it, a roll of masking tape, a pen, multi-meter with continuity and a 6-pack. It doesn't take too long, but you should trace everything out while you can spread it all over the floor.
    The engine loom will have two square-ish yellow plugs on it, and that loom that you've pictured will probably have the other one. I'm guessing that one you've got there runs from the drivers footwell, under the dash, and into the passenger footwell, connections junction boxes 1, 3, & 4.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    complete standard adm dash loom...extra wire looks like just extra earthing wire linked onto it
    edit: could be earthing for the HORN!!
    dose
  1. Replies: 2
    Last Post: 19th March 2012, 01:24 PM
  2. ADL: 4age loom and ae86 Jap ecu and Aus ecu
    By rke_011 in forum Car Parts For Sale
    Last Post: 24th October 2011, 07:14 PM
  3. JDM loom question
    By AIROCOBRA in forum Technical - Questions
    Last Post: 12th September 2011, 11:29 PM
  4. 16v bluetop ecu and loom question
    By h i t o r i k o in forum Technical - Questions
    Last Post: 20th September 2008, 09:21 AM
  5. Loom and ECU
    By muncher in forum Cars or Parts Wanted
    Last Post: 17th September 2008, 01:22 AM
