Results 1 to 8 of 8
Thread: spring rates from lbs to kg
    Glenn
    North Ringwood
    Default spring rates from lbs to kg
    how do you go from lbs to kg as i have 2 sets of springs here 1 set is 250 lbs per inch of movement and 1 set of 275lbs can some one help a old bloke to convert to kg please
    West
    Well theres 2.2 pounds in a kg and theres 25.4mm in an inch.
    Got maths?
    Brad
    Central coast
    To convert kg/mm to lbs/in, divide by .0179.
    To convert lbs/in to kg/mm, multiply by .0179.
    got that from dimitris coilover thread
    Mt Macedon
    1kg = 2.2lb
    1mm = 0.0394"
    Therfore:
    1 kg/mm = 2.2/0.0394 lb/in
    = 55.9 lb/in
    So from kg/mm to lb, multiply by 56. From lb to kg/mm divide by 56
    Or even easier,
    EDIT - Beaten by two... I must type slow.
    Glenn
    North Ringwood
    gee guys you could of worked it out for me as my brain hurts 275lbs to kg and 250 lbs to kg
    Glenn
    North Ringwood
    thanks guys
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    275lbs = 4.9kg (~5)
    and
    250lbs = 4.5kg
    *Thats spring rates not mass obviously
    Dave
    ive just seen this thread.
    google has this brilliant command called "convert"
    for instance if you google:
    convert 6kg/mm to lb/inch
    it will tell you.
    i am yet to find a unit of measurement it can't convert. you just gota make sure you have the correct units (spelling etc)
    - Blaise Pascal
  1. Harder spring rates, ride height and compressed rates.
    By Breaka in forum Technical - Questions
    Last Post: 13th November 2009, 01:12 PM
  2. Replies: 0
    Last Post: 4th September 2009, 11:06 PM
  3. Spring Rates
    By Dan_AE86 in forum Technical - Questions
    Last Post: 12th October 2007, 04:24 PM
  4. Spring rates
    By thekid in forum Technical - Questions
    Last Post: 17th November 2005, 02:16 AM
  5. spring rates
    Last Post: 12th September 2005, 09:02 PM
