Results 1 to 5 of 5
Thread: tacho in a ke70
    alex
    Inner West Lad
    Default tacho in a ke70
    hi guys a have an autometer 5'' tach which i installed on my ke70. Ive followed all the instructions and it works when i hook it up. But, as soon as i touch it to the negative on the ignition coil the motor turns off and i the car wont kick over again. Any ideas on what my problem could be?
    Veteran Skylar's Avatar
    Ken
    If it works why are you doing any more than getting it working???
    And what are you touching to the coil negative?
    alex
    Inner West Lad
    I connected it all up, started the car and it was all fine. I then turned the car off and it wouldnt kick over again. I disconnected everything and the car started again, i left the car running and connected everything, the last thing i connected to was the ignition coil, as soon as the cable touched it the car died. The diagram recieved with the tacho shows to connect to negative terminal on ignition coil.
    Mt Macedon
    Sounds like the wire you're connecting from the tacho is earthing out the coil negative, and so the coil will no longer spark.
    Double check your wiring and the wiring diagram (maybe it's wrong). Also check whether the wire you're connecting to the coil has a short to ground before you attach it (maybe there's an internal short in the tach)
    Tacho connections should be something along the lines of ground, 12V, headlight signal and coil negative signal. I may well be pointing out the obvious, but ground and coil negative are two different things.
    alex
    Inner West Lad
    thanks hen for ur advice,, i thought that was happening but ive checked over everything. Wile the tacho is connected i have no spark in my spark plugs. Do i need a more powerful ignition coil?
  1. ke70 tacho dash
    By Jacobxxx in forum Car Parts For Sale
    Last Post: 9th July 2010, 11:19 AM
  2. ke70 spirit wing and ke70 tacho
    By darksnake in forum Cars or Parts Wanted
    Last Post: 2nd October 2009, 03:09 PM
  3. KE70 tacho dash
    By kina in forum Car Parts For Sale
    Last Post: 30th September 2009, 03:18 PM
  4. ke70 Tacho Dash
    By sonsta in forum Car Parts For Sale
    Last Post: 17th May 2009, 07:43 PM
  5. KE70 Tacho wire
    By Daim in forum Technical - Questions
    Last Post: 19th April 2008, 05:05 PM
