Results 1 to 6 of 6
Thread: another noob suspension question
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Default another noob suspension question
    car - ae86
    use - street+drift+touge+track+collect dust and rust
    problem - how to figure what shock length
    so car is lowered with some 200mm -220mm springs in the rear of the ae86, forgot exact height of springs...
    anyways, yesterday while putting my S series back in teh rear, putting the shocks back in place made me relise how to figure what the length of shocks im going to need but would like someone to check with my thoughts
    so when car is on the ground, measure the shock height as its compressed...for example....compressed is 40cm...so ideal shock length at full extention should be about 50cm-60cm?....10cm more...
    by looking at the spring being compressed..i think the springs only compress atleast 1-2cm max as its rated 6kg springs..
    is this an ideal way to figure out best shock height to suit spring height?...i know theres a proper way but ive read threads and shit and it doesnt make any sense to me so im trying to make it as basic as possible
    dose
    Dave
    i dont think there is any real "proper" length but you want to try and get your shock to be in about the middle of its travel at static height.
    that way you have equal compression and extension.
    essentially so long as the shock never tops out, or bottoms out, its alright.
    so measure how long the shock is at static height (which i think you already have), and use this as the basis to work out what shock suits your height. use this figure as the mid point of the shock compression. it will take a bit of thinking, but wont be too hard. you will need the compressed and extended lengths of various shock lengths.
    - Blaise Pascal
    Moderator Sam-Q's Avatar
    Endeavour Hills
    as above, also can I suggest a more decriptive thread title
    Richard
    Liverpool
    oh ok...so just make sure it doesnt bottom out and top out
    sorry with title name...thread was made a few mins before i left work =p
    dose
    Endeavour Hills
    no complaining just a suggestion to get more help in your queries. Now as Dave wisely said ideally the dampner should be right in the middle of its stroke when the car is on flat ground at normal ride height
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    buy my shocks they can sit with stock springs but their short stroke im using 200mm springs at the moment with them
  1. Noob Question.
    By gumbie in forum Technical - Questions
    Last Post: 20th May 2009, 06:36 PM
  2. noob question
    By ke_70 in forum Offtopic Discussions
    Last Post: 30th March 2009, 07:22 PM
  3. noob question...
    By rugbymatt07 in forum Technical - Questions
    Last Post: 14th January 2009, 12:34 AM
  4. NOOB Question
    By Touge205 in forum General Topics (No Technical Questions)
    Last Post: 29th May 2007, 09:18 PM
