Results 1 to 10 of 16
Thread: CD Player wiring. Easy question.
    Veteran svenmate's Avatar
    Svenbot
    East
    Default CD Player wiring. Easy question.
    Hey all.
    Not really a technical question but I couldn't do this on my own.
    Car - Ae71
    Problem - I bought a CD player off a mate and the coloured wiring is different to the standard wiring. I usually just follow the cables to the speaker/terminal and then solder to the corresponding wire from the deck. This time, however, the wires are bunched and disappear behind the dash.
    The standard radio is still installed and i was wondering if maybe the cables just run to the radio and not to their individual applications.
    So my question.. Does the wiring for the audio gear run really high up in the dash or are the wires just cut long from my standard CD player?
    Sorry if this doesn't make sense. I confused myself writing it. Lol
    Here are pics.
    AE71 Build Thread
    Svenbot
    East
    Have consulted Dr. Bryant and will try his 11 secret herbs and spices.
    AE71 Build Thread
    Mark
    with a multimeter you could work it out pretty quick. However if you are still using stock speakers with the standard wiring you should probably redo the wiring because if its set up with a common negative it will blow the amp in the head unit
    Svenbot
    East
    So I used a multimeter on all the wires. Aaaannndd.... Nothing. No readings.
    I'll have to pull the dash off and see whats goin' down to pain-in-the-arse town.
    Will try tomorrow. Thanks guys.
    AE71 Build Thread
    Paul
    Maidstone
    ay
    if the staned one was working then its not cut !!! but i would re run all speaker wire and then find my power and memory wire and the neg and looking at the pic i say the reds powers and memory and black be the neg !!!! i had to wire in a cd player in a german car with all the wire up the shit !! aslo check the fuse in cd player and car
    2 in the pink 1 in the stink
    Site Supporter Javal's Avatar
    Josho
    Fail, here's how you do it:
    1. pull out your multimeter - you'll have one 12v power on one at accessories / on only. You will need a constant power, the standard stereo loom may not have this. You will also need 1 ground. read on, work out which wire is the odd one out and it will be this one. If you can't sus it out, check continuity to ground, one of them will have it.
    2. get a 9v battery. Pair off the wires. They're usually much like the ones on your stereo loom, i.e. light green + dark green or in your case it should be:
    Red + red w/trace
    blue + blue w/trace
    black + black w/trace
    etc etc, you should have 4 if you have 4 speakers installed.
    Next, get your 9v battery, put one of the paired wires on the positive, then as you are putting the other on the negative, one of the speakers will 'pop' or 'click'. This way you know what is going where.
    Easy.
    /salisburyelectronicsclass
    Brad
    Central coast
    have you got the plug you cut off?
    Josho
    Also remove your cluster surround to get a better look.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    also
    what cd player is it, find the following info and i will try and find a diagram for you
    Josho
    He knows what the CD player wiring is and should go, however it's adapting it to the existing loom that is the problem.
  1. BRISBANE: cd player and 6 cd stacker
    By plohl in forum Car Parts For Sale
    Last Post: 15th October 2011, 05:37 PM
  2. New CD player
    By Hazzard in forum Technical - Questions
    Last Post: 12th October 2009, 09:22 PM
  3. (TAS)-Fs: Response Dvd/cd Player, Dvd, Cd, Mp3, Mp4
    By Josh_04 in forum Other Items for Sale
    Last Post: 18th September 2009, 02:36 AM
  4. cd player Nav
    By eastcoastdrifter in forum Offtopic Discussions
    Last Post: 8th November 2007, 11:04 PM
  5. cd stuck in player
    By sharpie_13 in forum Offtopic Discussions
    Last Post: 20th January 2006, 08:28 PM
