Price and stock updated
Product - TechnoToy Weld on LCA Kit
Model Specific: Ae86 - but can be used for any lca you like
Info:
Double Adjustable
FK USA 3 piece Teflon Lined Rod End - 3/4" Bore & 3/4" Shank!
Steel base plate - to box in the LCA for added rigidity
Stainless Bushings
Stainless hardware - except base plate and block
Gain greater rigitity and precise camber adjustment & Track
Price:
US$180 + US$68 int ship
Stock - In stock
Ready to ship in Aus
pics please
pics up for your pleasure![]()
how do these roughly go on?
slice off your old mount and weld this on the underside?
yep pretty much, just measure up, make a cut to the length u want, the retangular block slots in the end of the arm, it gets welded in and the plate gets welded to the under side of the lca for added strength. screw in the rod ends and install.
price and stock update
would these work on an s13 lca? I can feel you cringe when you read this
THE EVOROLLA
none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
No reason why it won't work, just cut and weld in.
still got a kit in stock?
