Results 1 to 10 of 10
Thread: Gearbox bolt sizes? NEED ASAP!
    Senior Member PRIMRK's Avatar
    Dec 2009
    Cameron
    Brighton
    Default Gearbox bolt sizes? NEED ASAP!
    Well i just got a 4agze delivered and need to put it on an engine stand while i still have the crane i hired.
    Now i need the bolts, any one here know what size these bolts are??
    IF YOU DO PLEASE SMS ME ON 0436690611
    The engine crane i hired needs to be back at 2:30
    Veteran Skylar's Avatar
    Ken
    M12x1.5 I think, but it might be M12x1.25. Just get 4 of each.
    Dec 2009
    Cameron
    Brighton
    any one got any of these spare or know where i can get 4 of em??
    im in brighton near melbourne and have just been to the local auto joints and nobody has em...
    Ken
    go to a fasteners shop.
    Veteran Touge Boy's Avatar
    Modbury
    Most hardware shops should carry M12 stuff.... and they're a 1.25 metric fine thread.
    Jonathan
    Go to a wrecking yard. Ask them where abouts in the mud they last removed a Toyota gearbox. Pick the bolts up out of the mud.
    Jonathan
    The problem is, they often don't. In the worlds of construction, building, and home renovations... M12 x 1.25 is almost unheard of.
    You are best to fully strip down 1 Toyota car in the front yard, and keep every single little bolt in various glass jars for many years afterwards. You never know when you need 1. lol
    In my case it was more than 1 car, and I then got kicked out of home. But, all them little bolts are still kicking around somewhere.
    I bought 1 metric bolt the other day, it was $5.
    Calvin
    Kilsyth
    werd ^^^
    T18 in the build
    Senior Member *E7*'s Avatar
    Dave
    Eastern Melb.
    If you had no luck, call me, i have some in Clayton. 0422 328 332 and an engine crane if you need it again
    Dec 2009
    Cameron
    Brighton
    well i managed to get some...only thing was the longest i found where 75mm...so i had to modify the engine stand...good thing was the place i got the bolts also has 100mm cut off wheels too!
  1. Bolt sizes for 4age rebuild
    By DR86FT in forum Technical - Questions
    Last Post: 24th September 2011, 09:19 PM
  2. bolt sizes
    By shift_rook in forum Technical - Questions
    Last Post: 20th September 2009, 12:42 AM
  3. bolt sizes
    Last Post: 22nd June 2008, 02:04 PM
  4. Cusco RCA top bolt, can you get different thread sizes?
    By munki in forum Technical - Questions
    Last Post: 12th December 2007, 11:00 PM
