Results 1 to 9 of 9
Thread: step-by-step guide: changing diff centres
    The Ghetto
    Default step-by-step guide: changing diff centres
    hey guys looking to fit a 2 way but have never taken apart or replaced a diff centre before. Would someone be able to help by typing up a step-by-step guide with tools required and things to look out for? would muchly be appreciated.
    cheers
    Veteran biggo's Avatar
    Nick
    Noosa
    There is a step by step guide in the manual. It even tells you what tools you need.
    The manual can be found in the tech articles section.
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    i just did mine last night.
    basically,
    jack the rear end
    rest the car on very sturdy jacks as you will be laying under the car for a while.
    drain the diff oil
    remove rear wheels
    remove rear callipers/drums
    remove hub bolts, it should be 4 bolts
    axles should slide out (when i did this, one axle came out very easily, the other took a lot of yanking. so, if one is being a stubborn bitch, bring back one of the wheels you took off and bolt back onto the stubborn axle and boot it until it wobbles free.
    head back under the car, and disconnect the tailshaft, (4 bolts, 12mm i think?)
    then work your way around the pinion flange undoing the bolts. (think thats what its called) should be 10 bolts if your diff is a t series or 8 if its an s series.
    assuming that youv taken out your axles, your centre and pinion should wobble free.
    now that you have the pinion flange, undo the 4 bolts that hold the centre down and the 2 bolts that hold the bearings in place.
    wriggle free the centre.
    if your planning on using the existing crown wheel onto your new centre, then you have to undo the 8? bolts on the back of the centre that hold the crown in position and basically reverse from here on to get your 2 way going again.
    *while you have your 2 way out, (unless its brand new) get it shimmed otherwise you will be repeating this process when it starts single-ing
    The Ghetto
    ^^ thanks heaps hachi_dk sounds easy enough. I bought the centre second hand but it seems to be in still gd nick would i still need to get it shimmed?
    Veteran ae86's Avatar
    Western Suburbs
    its not hard, just a dirty job, depends on what diff it is really
    its better off to get new clutch packs than get yours reshimmed, if ur diffs a bit whiney might wana replace your pinion bearing and see that cw&p arent leaving grooves in the teeth
    The Ghetto
    where can i buy clutch packs for trd 2ways and approx how much would they cost thanks ae86
    Filip
    Jozzaville
    -also, i bought a centre that i thought was "alright" and it ended up singling on me.
    so best off to get it all done while its out
    also, which diff do you have?
    if you have a t series you can contact the website sponsor "spirited drive" and they should be able to hook you up with a LSD rebuild kit IF your diff is a t series.
    LSD rebuild kit from t3 set me back about $190 posted from USA.
    Western Suburbs
    hachi ur diff has diff shaped clutch packs to his
    those clutch packs arnt made for a trd 2way,
    message jesse streeter his msn is on his website, ask him to look for ae86 trd lsd rebuild kit part number for you and then he will get in contact with them and reply to you.
    Filip
    Jozzaville
    oops my bad, didnt know they were different.
    thanks
  1. Dub Step - Who else listens to it?
    By Low Style in forum Offtopic Discussions
    Last Post: 12th September 2010, 02:21 AM
  2. first step in the ae86 world
    By lovemy86 in forum AE86 Owners Forums
    Last Post: 2nd September 2008, 02:45 PM
