Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: RB20/SR20 5speed hybrid how to?
  1. #11
    Sep 2009
    Evan
    Barossa
    I ended up taking both casings off the RB box as i split the sr one today at work and threw it in our turbo wash and it came up sweet so i figured ill do both ends so it looks nice and then ill give it some good oil. thinkin redline shockproof. got new shaft seals and ill get a new front cover gasket and a shifter plate gasket. One thing i'm a bit suss on is what i believe is the reverse idler gear on the new [to me] rb box is a bix worn on the edge where it meshes so i might get it checked out but the rest of it looks sweet. i dropped the oil out of my other box and it was full of nice gold looking little shavings. its a shame the box doesn't want to come out of the car as easy as the new one came apart. oh well.
  2. #12
    Jonathan
    The wear on the reverse idler is sort of normal. No syncro. Don't worry too much.
  3. #13
    Sep 2009
    Evan
    Barossa
    Well i got the box out. was a lot easier with a little help from my housemate on the trolley jack. Once i got the box stripped i found a little difference. on the middle selector there is a spring loaded pin thing that goes to the selector fork and pushes off the center plate thing. the new box i have does not have this, i'm told its from a 32 where the old one is apparently a ceffy box. The gearset seems to be the same so i think it won't matter? anyone know if this will be a ? the wear on the idler gear was worse on the one that came out so she'll be right.
  1. SR20 to RB20 box in KE70? Let the hate rain down...
    By Plelz in forum Technical - Questions
    Last Post: 23rd March 2013, 07:55 PM
  2. SR20 Blacktop to RB20 gearbox?
    By deegee in forum Technical - Questions
    Last Post: 24th December 2010, 03:00 PM
  3. Replies: 0
    Last Post: 13th August 2010, 12:32 AM
  4. SR20 Hybrid Boxes
    By DR86FT in forum Technical - Questions
    Last Post: 17th June 2008, 11:08 AM
  5. RB20 ?
    By KYLE K YO in forum Technical - Questions
    Last Post: 16th February 2008, 08:05 PM
