Results 1 to 10 of 19
Thread: whats the ignition timing on a 16v 4age supposed 2 be
    Member 1sik20valve's Avatar
    Roy
    Wagga Wagga
    Default whats the ignition timing on a 16v 4age supposed 2 be
    hey pplz
    before the flaming , ive looked around and ive found a few different responses .
    my spaz mates have been playing around with my ignition timing , thinkin they know how 2 set it , now the car has no pull at all , and only way up top it has a strong pull , so im thinkin they advanced the shit outa of it . so i retarted it a lil and now runnin better , i just want to set it with the timing light properly , im runnin 98octane in her ,
    what the standard stock 4age 16v run?
    and how much more can i advance her to get a lil more power out of it safely?
    cheers guys
    Veteran Rice86's Avatar
    Richard
    Liverpool
    run over ur friend with what ever power you got left after he stuffed it up
    then set it to 0 on the plastic crank pully cover....you are talking about this right?...or u talking about the dizzy?..
    time to flame...USE THE TEMPLETE FOOL!! =p
    dose
    Richard
    Liverpool
    oh and 10' is safe, ive ran 10 before and it works wonder, dont forget depends on engine condition
    dose
    Roy
    Wagga Wagga
    yea . were r the markings?
    on the plastic cover?
    cause i couldnt see it .
    Richard
    Liverpool
    is the cover dirty?...most likely yes...
    clean it and you should see a series of numbers directly where the crank pully is but on the plastic cover, looks something like this
    "15, 10, 5, 0, 5, 10"
    dose
    Roy
    Wagga Wagga
    ill check it out now ,
    so i just set it to 10degrees? , and thats 10degrees advanced yea
    Richard
    Liverpool
    have to figure what ur mate did first to cause this power lose...
    there isnt enough info to give a good idea of what he stuffed up if u know what i mean
    dose
    Roy
    Wagga Wagga
    he just kept moving the dizzy around , clockwise and anti close wise .
    then driving it around 2 see if it went better .
    Richard
    Liverpool
    ok that case..you dont need to touch the crank pully timing...
    play with dizzy until u hear the car ideal nicely, thats it...if it ideals nice its pretty much as sweet as it'll get...if it starts to sound like its reving then its to advanced and if sluggish and pooping then to retarded...
    dose
    Jonathan
    The specs say 10 degrees, with the check connector in.
  1. [VIC] WTB: 16v 4AGE Coil Ignition Module
    By LEVIN86 in forum Cars or Parts Wanted
    Last Post: 2nd August 2012, 08:28 AM
  2. 4age, Ignition Timing
    By DearmanKE in forum Technical - Questions
    Last Post: 21st January 2012, 11:59 AM
  3. 4AGE Ignition/Exhaust/Intake timing
    By AE092 in forum Technical - Questions
    Last Post: 25th August 2010, 09:28 PM
  4. ignition leads - 4age 16v
    By electric mic in forum Technical - Questions
    Last Post: 20th August 2008, 11:12 PM
  5. Optimal ignition timing for 4AGE
    By Gullie in forum Technical - Questions
    Last Post: 7th May 2008, 12:04 AM
Tags for this Thread
