Page 27 of 31 FirstFirst ... 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 LastLast
Results 261 to 270 of 301
Thread: F series Diff info + Discussion
  1. #261
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    Brackets need a 1.5mm step both sides to get the caliper offset right, that will get done next weekend (my bro snapped a belt on his cnc mill) so should be the week after.
  2. #262
    May 2010
    Interested to see how you went. Any plans on selling a set of brackets? Or the cad file? Are you using any spacers behind the axle flange, or it just bolt on bracket, away you go?
  3. #263
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Does the shock mount get moved
    Sent from my SM-G900I using Tapatalk
  4. #264
    Lindsay
    Mackay
    brake place had trouble sourcing new rotors because dba changed the part no so thats put me back.
    yeah once i've proven it i'll get 5 sets made up.
    no spacers whatsoever, but the plate does need machining around the axle flange area to get the offset of the caliper correct and make it so the bearing is not sitting further out.
    The idea will be that's its a bolt on bracket, just add r31 or vr commo calipers and either 256mm s13 disk or 276mm pulsar disk (depending on bracket, there will be 2 types)
    I haven't had to move my shock mount.
  5. #265
    I'd be keen on a bracket pending price.
  6. #266
    Kaan
    Emerald
    Me too
  7. #267
    Lindsay
    Mackay
    I've just sent the cad file away for the small disk bracket to get a pair made up.
    Looking at the catalog the options will be a Pintara 258mm disc, 10mm thick DBA614 or s13 257mm disk, 9mm thick DBA904. The Pintara disc is slightly cheaper but the s13 disk is available in a slotted type.
    The caliper sits behind the hub face by about 5mm so should still be able to put 14" wheels over top. depending on wheel design of course.
  8. #268
    Lindsay
    Mackay
    Well i've been dicked around by the brake shop but have a redrilled disk on there for the big disk version for now.
    this is using vr commodore brakes. r31 will get test fitted next.
    wheels are 14x7 0 offset te37s. ill be trying my 15" rotas and my mates 14" hoshino streets.
Name:	disk brake upgrade 01.jpg
    brakes are behind the hub face
Name:	disk brake upgrade 02.jpg
    plenty of shock clearance and a banjo fitting to replace that bulky commo line will make more room
Name:	disk brake upgrade 03.jpg
    5-7mm from the 14" wheels. i will move the calipers inwards another 4mm to make even more room for this version. the small version will have about 15mm more room.
Name:	disk brake upgrade 04.jpg
    hub centric ring holds the disk in the middle. i just need to either source or machine thinner ones
  9. #269
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Would you know the piston size of VR commo caliper?
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
  10. #270
    Lindsay
    Mackay
    38.5mm same as r31.
    R31 calipers have more clearance than commodore ones and the fins can be ground down to make even more clearance. brake pads have slightly different mounting but the same surface area.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
