Page 29 of 31 FirstFirst ... 19 20 21 22 23 24 25 26 27 28 29 30 31 LastLast
Results 281 to 290 of 301
Thread: F series Diff info + Discussion
  1. #281
    May 2010
    How did you go with the adapters Jip? :>
  2. #282
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    I've got 3 sets of tarago to s13 disk getting made and 2 are spoken for. Mine have been on the car for months.
  3. #283
    Veteran Konakid's Avatar
    Henry
    Eastern
    Im out mate, me and a friend have decided to get some made up to suit a bigger, r34 caliper and rotor setup.
  4. #284
    May 2010
    I'm keen for a set?
  5. #285
    Veteran skizzamods's Avatar
    Oscar
    Adelaide Hills
    But from what I've read IRS gears and LSD will still work in a Live Axel pumpkin.. Correct?
  6. #286
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I can measure length of spline and thread on pinion on an altezza gear if you like. Do you have a live axle pinion length available?
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  7. #287
    Marco
    "9th March 2009, 01:09 PM #7
    slydar slydar is offline
    also in every case so far that i have found, an irs ring and pinion will work in a live axle diff and vice versa."
    Just found this in another forum topic.
    Length from end of pinion to pinion gear bearing spacer face =168 mm
    Length from end of pinion to front of bearing face = 136.5 mm
  8. #288
    Henry
    Eastern
    Ive got RA65 IRS gears in my tarago live axle. Would IS200/altezza gears be the same as RA65/MX73/MA61 etc? i would have assumed so.
  9. #289
    Marco
    Hi Kona, out of interest what ratio is that? Going by the Eden Valley video, the ratio is perfect for the turbo 22r.
  10. #290
    Henry
    Eastern
    3.73. yeah works well with the 205/50/15's
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
