Results 1 to 10 of 19
Thread: Oil filter relocation.
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Default Oil filter relocation.
    Hey fellas,
    Where the oil filter once went, do you need a gasket between the block and the metal piece that is the relocation kit?
    Senior Member jaz_ae86's Avatar
    Jason
    Southern Suburbs
    Yes, and preferably a high temp seal as you won't be changing it regularly like the ones on the oil filter.
    Timmy D
    North
    another quick question, sorry to high jack.
    it it ok to put an oil cooler in line with this set up ?
    as in engine, line to - oilfilter relocator, line to - oil cooler, line - back to engine?
    JJ
    Jason
    Southern Suburbs
    Yeah it is Tim, that is how oil cooler kits go, your choice to filter pre or post cooler, except on thermostat control where the cooler has to sit post filter/relocator.
    One other thing of note is that you pay for quality in oil coolers kits and oil is what keeps your motor going. The GREX type V kit for AE111 retailed at over 130000 yen new and that is thermostat on block.
    Jun 2009
    Damian
    where can i get a seal from
    Timmy D
    North
    i already have a kit that came with my motor but its not on the car. i priced up a pwr oil cooler and some speed flow fittings and line.... pretty pricey but i dont think i will be happy with a "kit" id rather run my own line and make it really neat
    JJ
    Veteran blair's Avatar
    Blair
    SEQ
    does having so many lines/extra volume put more load on the oil pump?
    Jason
    Southern Suburbs
    I would try , O rings are measure OD, thickness and usually imperial dimensions.
    The addition of remote filter and or cooler will reduce system pressure. How much I don't know but considering that 4AG oil pumps run pressure reliefs, the overall system pressure may be the same with as without. Extra load would be negligable as the relief will pass excess oil/pressure, the increase in use upto that point at which it relieves cannot be considered additional load.
    High quality oil cooler systems will result in minimul pressure loss and maximum flow of oil.
    You should run the latest series of oil pump as you can for better pressure/flow. DO NOT RUN pressure relief style oil coolers on 20v! ie OE style
    Veteran Touge Boy's Avatar
    Modbury
    Tim, I have the Trust AE86 kit minus relocation but with thermostat on the sandwhich plate on my car (Old kit off of Jay's Green 86 coupe) and it's the bee's knees. Everything lines up perfect, and on wednesday I didnt see oil temps above 85 degrees. So, there is merit in running a proper kit.
    That being said, some people are running the cheaper "Generic" kits (Like Robo I believe and his car cops an absolute flogging) and it seems to work well. i have heard stories of pressure drops and restrictions and leaks, but Ive never seen them myself so i cant comment.
    Reeece
    Casula
    Ive had a ebay one for 2 years its as good as the rest IMO
  1. Brand new oil cooler kit...with oil filter relocation
    By mong in forum Car Parts For Sale
    Last Post: 22nd April 2012, 07:49 PM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. Trust Oil Cooler with Oil Filter Relocation kit
    By patience in forum Car Parts For Sale
    Last Post: 5th August 2009, 07:59 PM
  4. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
