Results 1 to 5 of 5
Thread: surge tank in a ke70
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Default surge tank in a ke70
    doing my 4age convo and im running a surge tank. can anyone correct me if im wrong about the lines and where they go?
    mereki.
    ~KEEP DRIFTING FUN~
    Senior Member Dylan's Avatar
    Dylan
    Dave
    i think that tank is designed to mount up the other way?
    either way, in general you should do it from this.
    going from the LOWEST pipe to the HIGHEST:
    - feed to high pressure pump (fuel rail)
    - feed from low pressure pump(life pump, from tank)
    - return from fuel rail
    - return TO tank (over flow to tank)
    you can prolly swap the middle 2 pipes around, but you need to have the overflow to the fuel tank at the highest point, and the feed to the high pressure pump (fuel rail) at the lowest point.
    heres a tech article i did on my surge tank setup
    some pics in there of it setup
    - Blaise Pascal
    Mereki
    Badassville
    ok then ill do that but the overflow to tank, do i use the carbon canistor line on the fuel tank and rid the canistor cause theres;
    .fuel to motor
    .return from motor
    .carbon canistor
    mereki.
    ~KEEP DRIFTING FUN~
    Member 1sik20valve's Avatar
    Roy
    Wagga Wagga
    this should help
  1. UNDERCAR surge tank KE70
    By ke70dave in forum Technical - Articles
    Last Post: 5th September 2013, 03:29 AM
  2. Surge Tank Setup 4age KE70 Need Simplified
    By ke70 xx in forum Technical - Questions
    Last Post: 15th June 2009, 08:12 PM
  3. for sale , surge tank, aus fuel tank, hood linning + more
    By hillclimb86 in forum Car Parts For Sale
    Last Post: 20th June 2007, 12:20 PM
