Results 1 to 10 of 10
Thread: Broke my panhard rod mount off
    Member D4NI3L's Avatar
    Jun 2009
    Daniel
    Croydon
    Default Broke my panhard rod mount off
    my car is a stock 4k ke70 with a lock diff
    the other night drifting i snaped my panhard rod mount off my ke70, the mount has been torn apart between where the panhard rod bolts on and where it attaches to the body
    just wondering if anyone has had this happen, im wondering if i should make a stronger mount or get mount off another ke70
    Life is best spent \\Sideways//
    Mark
    probably should of stayed away from the gutter
    Thats pretty nuts though that its gone at both ends! You think one end would go and the other would bend.
    Anyway. The good thing is this is the perfect excuse to upgrade the diff
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    is it only the body mount end ? i assume it has been bent/damaged previously and therefor has been flexing until it broke..
    get another good condition mount that has been removed by drilling out the spot welds and get a good welder to re attach in the right place..
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
    Mark
    oh hang on i get what you mean now
    Dan
    SE
    i've done it, if its just torn apart not snapped off u can go down 2 bunnings get a flat bar ( bout 10 bux ). cut it 2 size one for the front and 1 for the bak, drill 2 holes at the top of the mount and match that up with the flat bar pieces and drill the 2 holes on each flat bar then bolt it up and drill the hole for the panhard mount .
    if u want it done properly cut nd shut off a one from wreckers or weld in a RHS post cut 2 size
    Moderator Sam-Q's Avatar
    Endeavour Hills
    pics?
    need a welder?
    Jun 2009
    Daniel
    Croydon
    all good talked to cal at TTG and him and his bro are going to custom make me a stronger mount
    Jun 2009
    Daniel
    Croydon
    for S#!T's and giggles tho i'll up load some pics lol later
    Site Supporter Javal's Avatar
    Josho
    I've seen a section of box steel with one side cut out used as a replacement panhard rod mount.
    It was not the most glorious of efforts, but it can be done well.
    Dan
    SE
    pics of calvin's work must be had wen done
    and pm/post me a price
    spray sum sound deadener +sand mixed in and it shud hide the new metal well
  1. Panhard rod
    By Lancerdup in forum Cars or Parts Wanted
    Last Post: 24th July 2012, 06:45 PM
  2. Panhard Rod Mount Buckled =S
    By bally in forum Technical - Questions
    Last Post: 18th May 2011, 08:48 PM
  3. Panhard rod
    By Low Style in forum Cars or Parts Wanted
    Last Post: 9th December 2009, 06:16 PM
  4. Panhard Rod
    By loc33e in forum Cars or Parts Wanted
    Last Post: 21st November 2007, 05:49 AM
  5. Panhard rod
    By eightsixboy in forum General Topics (No Technical Questions)
    Last Post: 10th June 2007, 08:29 PM
