Woah, can we take a step back here?
If you have a larger bore, the swept volume increases right? and the combustion chamber volume stays the same. Wouldn't that mean an increase in compression with the head gasket thickness being constant?
This is assuming you have standard replacement pistons, not some lower compression piston.
Lastly, I have half mil. oversize standard replacement pistons in my 4AGE. It seems to go fine.
