Probably just have it on TPS.
Around the idle parts of the map (the whole 0% line) have the fuel at about 3.5ms. At the 6% line, have them all about 4.2ms. Ignition timing should be about 10 or 12 degrees around the idle parts of the map. Double check the timing with a timing light once it's running.
If you have no ISCV, you will have to unwind the idle speed screws on each throttle.
