Results 1 to 10 of 11
Thread: timing for a 4k
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default timing for a 4k
    just a quick question
    i advanced my timing but it over heats to quick so
    whats the standed timing at?
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    5 deg is about right.. anything from 2 to 10 deg btdc is fine
    vacuum hose disconected when setting it
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    a 4k overheating?? instant headgasket fail.... we always wound the timing on as far as it goes so it would kick back when u cranked it over then wind it back off a couple of degreese!!!
    AE86 THE BEST
    Site Supporter Javal's Avatar
    Josho
    LOL. You running 98RON homeboy?
    Overheating is a dead giveaway that your shit is pinging like nobodys' business.
    Also Eddie is bang on in regards to the 4K instant fail HG
    Mark
    Southern
    ive never had a 4k over heat unless its had a dodgy thermostat, water pump impellor broken off, blocked radiator or blown h/g,
    ive never even had a clutch fan or thermofan on one as they just dont produce enough heat to need it.
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    8 deg. Dont worry, if its a headgasket you should be able to drive it like that for a few months
    Josho
    Ok, Overheating after you've made only one change which is very likely to induce pinging if not used in combination with higher RON fuel = pinging.
    Mark
    Southern
    you shouldnt be running enough timing to make it detonate, its loosing power and torque with that much timing
    and any half resonable 4k cooling system is usually more than enough overkill to cope with this
    the question has been answered many times.. timing on a 4k isnt all that important ive actually done dyno testing. (sad i know)
    maybe it had too much advance, detonated, and now has blown the headgasket because of this. ?
    Josho
    Plausible, but i've seen KE's running hotter because of advanced timing running 91RON. It really needs a bit of investigation.
    Senior Member resol's Avatar
    steve
    vic
    my 4k i was an older version maybe from a ke55? idk, but the dizzy cap was an older from an older model car.
    always ran BP ultimate 98RON fuel and timing aorund the +40degree mark. ran excellent no pinging, and didnt over heat, and yes you could notice the little bit of poke around 4k that the advanced timing gave.
    but being the older version 4k it was designed for LEADED fuel, which apparently ment the head was able to deal with the high timing....
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  1. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  2. 4k timing cover removal
    By Dazzla86 in forum Technical - Questions
    Last Post: 6th November 2010, 09:52 PM
  3. Wtb - 4spd gearbox for 4k motor and engine mounts for 4k
    By Snoozy in forum Cars or Parts Wanted
    Last Post: 17th July 2009, 02:18 PM
  4. 32/36 Weber, 4K Extractors, Other 4k Performance parts...lol
    By HarlemSessions in forum Cars or Parts Wanted
    Last Post: 20th April 2009, 05:20 PM
  5. 4k timing marks
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 16th February 2008, 12:08 PM
