This is listed 1000 times on this forum, and also Toymods.
HiLux 4WD from the 1990's. LN105 is one model, but there are lots of various HiLux 4WD models. Most have the same brakes.
Disc is a Peugeot, I forgot what model. (It is 20mm thick, and centre hole is about the same as XT130 one). But you have to put it on the lathe and reduce the diameter down to 254mm from memory. Also you have to take 1mm off the mounting surface of the disc. Also you have to drill the 4 holes slightly bigger.
You will have to use XT130 or RA40 or RA23 steering knuckles. This will slow the steering down just a little. If you use AE86 knuckles, the disc will hit the control arm.
You use the XT130 hub and bearings.
