Results 1 to 10 of 19
Thread: Brake Booster Vacuum Lines
    Veteran bigm's Avatar
    Gold Coast
    Default Brake Booster Vacuum Lines
    Car - MX73
    motor - SR20DE+T
    use - Not Much ATM
    problem - Want to know if i i can put boosted air through the vacuum line that goes to the brake booster from the intake manifold. I think it should be right, but havnt had a turbo motor before so checking.
    occurs/started when - I put the motor in
    personal situation - I either put it on or i dont.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    yep hook it up likenormal
    AE86 THE BEST
    Jonathan
    There is a 1-way valve, so retain it, and make sure it points the right way.
    Gold Coast
    Thanks guys
    The valve is in the booster or the line?
    Veteran biggo's Avatar
    Nick
    Noosa
    usually toyotas have them inline
    Site Supporter Javal's Avatar
    Josho
    This. It's a little white / beige dinger that has a bracket attached to the firewall.
    Gold Coast
    The one that isnt there. that would be right.
    are they model specific of generic?
    Josho
    Pretty generic.
    KE70
    AE71
    AE86
    Gold Coast
    Appreciate that Javal. Thanks
    Ill locate one on tuesday
    Gold Coast
    which way is the correct way? air flowing to the Booster?
  1. Replies: 4
    Last Post: 26th June 2012, 09:14 PM
  2. Vacuum Booster-less Brakes
    By PRIMRK in forum Technical - Questions
    Last Post: 15th December 2010, 10:33 PM
  3. BRake Lines - Brake Booster One-Way valve
    By bigm in forum Cars or Parts Wanted
    Last Post: 29th January 2010, 06:56 AM
  4. 4AGE Vacuum Lines
    By 45aken in forum Technical - Questions
    Last Post: 21st April 2009, 09:34 AM
  5. 20v Brake Booster Vacuum Problems
    By sprinterturbs in forum Technical - Questions
    Last Post: 15th December 2005, 07:55 PM
