Results 1 to 7 of 7
Thread: second hand shocks.
    Mick
    Southside
    Default second hand shocks.
    i own a ke70. it has been lowered and has fairly wide wheels on the back..the guards have been rolled and flared by me..now im lookin to find some shocks which would make the back stiffer so its not so bouncy.
    im on my way to u pull it this week what are some good cars that i can get shocks out of which would make it less bouncy if possible.
    Veteran shift_rook's Avatar
    SE Burbs
    in bouncy you mean?
    Jonathan
    If you are after standard replacement shocks, that by chance maybe a bit better than what you got, go after these cars:
    AE86 Sprinter (of course)
    KE70 - AE71
    AE95 Corolla Wagon 4WD
    TE72 T-18
    All the above use the same rear shocks. Also RWD Celica ones will fit.
    For shorter rear shocks to suit your lowered car:
    XT130 Corona sedan or wagon
    -perfect length and fitment.
    Also look at Commodores...
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    vl wagon or similar
    short stroke, marginaly stiffer to stop the bouncing
    pajero (approx 96 maybe ?) very stiff and very short stroke, the bottom mount has a steal sleeve in the bush that is a perfect tight fit on the ke70/ae86 lower shock mount
    remember to check your bump stop clearance, because you will struggle to find a shock that will controll hitting bump stops
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
    Mick
    Southside
    ok thanks..what is the bump stop clearance???
    Senior Member Dylan's Avatar
    Dylan
    You say it's been lowered, it could be getting close to touching the bumpstops on bumps. Most people cut a section off to solve this.
    Mark
    Southern
    jack your car up under the diff,
    look at the bump stops (big black rubber things that are bolted to the chassie inside the rear springs)
    look and measure the clearance between the bump stop and the diff ( spring seat actually)
    if its less than 3/4 of an inch or say about 20mm it isnt enough
    how much lower than standard is it ?
  1. Need a hand..
    By DAMO46 in forum Sydney & NSW Events and Discussion
    Last Post: 29th November 2009, 04:25 PM
  2. Right hand side s series ae86 hand breaK cable
    By johnO2 in forum Cars or Parts Wanted
    Last Post: 9th July 2008, 11:42 AM
  3. help with Hand brake
    By jase ek in forum Technical - Questions
    Last Post: 16th July 2007, 02:44 PM
