Results 1 to 5 of 5
Thread: Where can i get my rims welded
    Bayden
    south australia
    Nurioopta
    Default Where can i get my rims welded
    Hey guys
    im looking for some where which can weld one of my alloy rims welded and rolled back straight.It bent off and cracked a bit.
    Numbers or even names would be good
    cheers Bayden
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    there's adelaide wheel and rim works and extensive wheel repairs they are both on south rd in the richmond area
    ive used extensive wheel repairs as they were the most friendly and cheapest
    (i think adelaide wheel and rim works just quoted more as they couldnt be bothered doing the job)
    Bayden
    south australia
    Nurioopta
    ok cheers man hopeing wont be to much to fix other wise ill have to buy another one luckliy only 215 ech so hoping under 80 to fix
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    lol it will be about triple that to fix.
    they should be called expensive wheel service
    Andy
    Veteran Touge Boy's Avatar
    Modbury
    Fixed.
    Not to mention both those shops are full of clowns that dont have a fucking clue.
    it took AW+R 8 weeks to get my ROH's back to me. And then When i cracked it and took em across the road to extensive, they only took 2 days to fuck em up even more. Ended up fixing them myself and well, fuck me, it worked. Idiots.
    Take them to a small but proper engineering firm, they'll have the right equipment to do the job if they're worth their salt. And will probably get away with it for a couple of cartons if they're that way inclined.
  1. Is it possible to to get rims welded?
    By ke55pig in forum Technical - Rims & Tyres
    Last Post: 19th September 2009, 07:25 PM
  2. Welded Diff
    By dreny in forum Technical - Questions
    Last Post: 31st July 2008, 02:25 PM
  3. rims, welded sprinter center, t-50, interior bit
    By DODGY86 in forum Car Parts For Sale
    Last Post: 3rd April 2007, 11:36 PM
  4. Safety of welded 3 piece rims
    By starni_boy in forum Technical - Questions
    Last Post: 4th April 2006, 12:17 PM
