^^ Use the original 16v fuel rail and injectors matey.
Hi, I have just purchased a set of 20V quad throttle bodies on the 20V manifold, the stock 20V manifold has the injectors in it, so when I bolt the ITB's onto this adaptor for my16V head, where will the injectors go?
Injectors circled in red.
Like so... This is the T3 Kit, AE101 S/T throttles with T3 Trumpets and a 4AGZE Injectors and rail. But NA Smallport or bigport will work exactly the same.
FYI... For this kit, You can use either a KE70 or AE71 (Cant remember which, will update when i do) throttle cable too... Bolts straight in and is the exact right length.
thanx for the help guysand sorry for the confusion, this is the 1st time ive mucked arround or even used quad throttle bodies before, so do you have any smallport adapters in stock? Cause i will be needing one as soon as you can get it
i have the money
cheers.
Thanks for the explanation and pics again Ben. Drift Kid do you get the idea now? if not just PM me and ill sort you out.
New stock has arrived!
does the quad adapter come with a gasket ??
no gasket supplied.
just the adapter on its own.
Would I need to replace the throttle cable in my stock 16v to fit the new throttle body
you will use the standard metal gasket from your 16v engine. the same gasket from the stock throttle body to the head of the 16v will suit this, not the butterfly circle gasket if your referring to bigport TVIS
JDM ae86 throttle cable should fit
dose
