Hey guys.
In the process of wiring my SR20 into the cressida.
1. All is well, All my relays are good to go, Thermo etc work, have injector power. But, my fuel pump doesnt work. The relay is good (have checked by putting power to the trigger point on the relay). The trigger is hooked upto the Black Purple wire in the ECU which according to several diagrams is fuel relay. There is no power through this wire with the key in the ON position.
I could be missing something, is there another wire that i missed but used FAST EDDIES wiring diagram and everything else has work.
2. How Much voltage should I be getting through my spark plugs? it is only reading between 0.01 and 0.02.
3. What are the 2 Wires on the plug that go on the alternator for?
Thanks for any help guys.
