yeh just need an approximate weight with tail shaft. been trawling the net and dont have scales big enough at home. thanks
I have a diff housing without mounts, 2 drums without pads, 2 axles laying around as well as a dud center, if you like I will weigh them up then you will just need to add them up and add a few kg for the missing mounts, and the shit inside the drums
ok I got my scales out:
housing - brackets, -axles, -brakes, inc center: 25.1kg
axles: 5.6 x 2 = 11.2
brake assembly ex drums: 2.5 x 2 = 5kg
so all up 41.3kg then just add the drums and the brackets. If I manage to pull a drum out I will let you know.
thanks for that sam, always a wealth of knowledge. it was so i could post it but i just guestimated and when i rocked up they threw it on the scales and with no oil, a complete t series diff with tail shaft is 76kg.
