Results 1 to 5 of 5
Thread: Guard lipping question.
    Default Guard lipping question.
    Quick question,
    When lipping rear guards by hand (rubber mallet + heat gun) does everyone normally cut the lip in places to make it fold easier, or should i just be able to do it if i purchase a dolly and just hit it harder? (car is a s13, double layer lip on the rear if that changes anything compared to ke/ae)
    Thanks,
    Veteran Touge Boy's Avatar
    Modbury
    Be very careful how far and hard you hit the guards on a S13. They'll pop in over the bodyline crease above the guard and then they're fucked.
    I just hit them fairly firm with a plastic faced hammer and a block of wood wrapped in a couple of rags, and heat it up with a heat gun.
    Havent cracked any paint or creased any guards yet.
    You will crack the paint inside the guard, but just paint over it in some satin black paint to seal it again.
    Veteran Konakid's Avatar
    Henry
    Eastern
    Guard roller and heat gun if you care.
    Ball pein hammer and muscles if you dont.
    RT142 Estate.
    AJPS.
    Nov 2009
    Eastern Suburbs
    ^+1
    u can do the front of an s13 easy, did fronts easy but used guard roller for the rear and still cracked slightly
    personal choice....
    Senior Member resol's Avatar
    steve
    vic
    matt, why didnt you msg me? bring your car round next time your free and i'll sort you out mate.
    s13 guards are easy to lip with guard roller, wont dint the 1/4, and depending on paint wont crack either.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  1. Rolling/lipping guards
    By hachi_dk in forum Technical - Questions
    Last Post: 29th August 2009, 05:49 PM
  2. Guard Lipping Tool ?
    By 44GTE in forum Technical - Questions
    Last Post: 18th April 2009, 02:28 PM
  3. guard question
    By damo46 in forum Technical - Questions
    Last Post: 18th April 2008, 09:43 PM
  4. guard flaring question
    By EVOSTi in forum Technical - Questions
    Last Post: 27th January 2007, 10:41 AM
