Why would you bother?
yes? or no?
pros and cons
please no shit talk just want to find some info
you play halo?
add me GT: samnbhnc
well i just want to do something other a 4age like every other 12year old on here
you play halo?
add me GT: samnbhnc
Whats wrong with a 4age? It's a proven win.
Could do 7age too. I just don't think all the work would be worth it.
if its your cup of tea then go for it - rotor's love to catch fire!
just bear in mind that an NA rotor makes about half the torque of a piston engine in the same capacity - an for it to make any power its going to be way loud - porting, exhaust / intake will easily smash 100db
turbo would be good.
nothing really different to any other engine conversion. all mounts custom - tail shaft etc.
well it was just a thort from the weekend
one of my friends took me for a drive in his 287hp 13b turbo fc it was amazing but yeah it was stupidly loud and iv been doing some research on 7age's i think i might go that way
what are 4agze's like in n/a format??
i havent seen many if any one has one can you link me to there duild thread
you play halo?
add me GT: samnbhnc
GZE in na = Rubbish - comp is way to low - they need to have forced induction of some sort. why gze non turbo? are u on your p's? just go NA 16 v or 20 v
yeah p's
was just thinking gze iv been told there heaps stronger but i guess i could probly get the stronger parts off a gze and put them in a smallport and one of my mates has a gze ae82
you play halo?
add me GT: samnbhnc
Years ago, my brother and myself put a 13B turbo into an AE86, it was GREAT fun, ran a 12.5 at the drags, cheap, easy and FAST. We used a Haltec fuel only ecu, 12A turbo distributor and front cover(distributor has retard on boost function) it cost bugger all and went fast.
Sundee86 I disagree with the NA rotor making about half the torque of a piston engine in the SAME capacity, as you would know a 12A is roughly 1.2litre SWEPT DISPLACEMENT and a 13B 1.3 litres. They make MUCH more torque than an engine of the SAME capacity, hence the greater output compared to engines of the same capacity.
My background is actually rotors, I use to build lots of em back in the late 80's early 90's, mainly NA, BP's and PP's, alot went to Sports Sedans, they deliver a very flat torque curve over a HUGE rev range.
Alot of people bag ported rotors saying they have to idle at say 2000rpm this is also crap, and to me is a rotor not set up correctly. My daily back then was an RX3 coupe with a 13B PP, even on a weber carb(later autronic efi) it idled at 800rpm! alot of people couldn't believe it was PP! and it would pull hard thru to the high 10's, I usually used around 10,300rpm. It made about 180ftlb of torque at about 9500rpm(long time ago, trying to remember) with this 180ftlb of torque over a VERY large rev range an NA 4age would not even get close!
I remember once I was in a petrol station putting fuel in the RX3(this use to happen on a VERY regular basis) any way another RX3 pulls in romping(term we use to use for lumpy idle) it's arse off, any way the guy hears mine and after filling up he comes over and asks what I'm running (he said he was running a monster) he says it sounds like a small bridge(due to the low idle speed) I said "No mate it's a PP", he says "sure it is, do you know what a PP is?"
I reply "I hope so, I machined the housings and built the engine", his jaw drops as I open the bonnet, sure enough it's PP, he asked how I got it to idle so well, I told him that the weber IDA is a very adjustable carb and not many people really know how to set them up right.
If you want to go a rotor, why not, I would go a rotor over say an SR anyday, I like the way a rotor hits(especially a turbo one).
yeah but ill be going for a na and cheap and from what iv seen/heard cheap rotor isent going to happen
you play halo?
add me GT: samnbhnc
