The first bigport bottom end I left outside over the weekend. Woops! The bores have got a bit of surface rust on them so going to throw it in the scrap bin if nobody wants it.
Come take it away free!
I got 3 Bigport's and only needed some parts so I am selling the rest.
Pickup is from Bayswater VIC I could post stuff too. If you think its too expensive PM me what you wanna pay.
1:- I have a complete 2nd Gen bigport with black and red covers comes pretty much bare. Has FWD alternator bracket, Looks as though the waterpump is RWD front housing with a FWD rear housing. Supposedly was running but the oil was filthy and looking down inside through the plug holes pistons look a bit carboned. It probably would run but I'd rebuild it.
$150 I think is fair.
2:- Bigport Block 4 Rib ok condition I was going to bore out to 20thou as it has a bit of rust in the number one bore and glazed in the others.
Comes with Crank, pistons, bearing caps, drain pickup, sump, oil pump, rear oil housing, harmonic balancer, all complete bottom end just in bits.
$50
3:- Bigport FWD TVIS Intake manifold comes as shown without the yellow plug.
$30
4:- Two A/C Compressor's unknown condition was told one was working also have another very dirty one which I'll clean up. Dirty one can be seen in the first bottom end picture.
$30 for both
5:- 200mm Stock Bigport Flywheel. Flywheel looks pretty stuffed would work but I'd machine it. It comes with standard bolts.
$20
6:- Set Piston Rings for Stock size pistons same as in this link
$20
You can PM me or even call or SMS 0407465717
Cheers Pete
im in mixed minds about the carb manifold and head.
how bad is the corrosion in the water ports as its hard to tell in the pics
This is the worst part in the number 2 port. Its only very lightly pitted.
Hope these help. Like I said I'm open to offers. As I don't really need this stuff rather it gone.
Replied man!
Going to throw all this on ebay soon if no more interest is shown.
willing to sell just the carby manifold?
otaku.harley
はちろくブログ
sent you a PM
if no one takes the carby manifold let me know.. and ill take it.
