Results 1 to 10 of 14
Thread: 4age starting issue
    Default 4age starting issue
    Car - ke70 4age conversion
    motor - bigport 4age
    use - weekender, hills runs
    problem - wont always start just clicks
    occurs/started when - i got the car a few months ago and is geting progressivly worse
    personal situation - want it fixed coz i wana fucking drive it
    when i bought the car it already had the problem and its just slowly getting worse, when u turn the key it just makes a click noise and the fuel pump starts up but starter motor wont kick over, sometimes it will start first try and other times it can take up to 30 turns, it seams to get worse when the engine is warm aswell, its been to a mechanic who changed the starter and it did the exact same thing unless the starter motor it was swaped with is also stuffed im out of ideas, is there any other things to look for? has anyone had a similar problem?
    any help would be appreciated cheers
    Veteran timbo's Avatar
    Tim?
    Wild West
    If it gets worse as the engine gets warmer then it would most likely be the starter motor overheating. There should be a heat-shield between the starter and the exhaust manifold to stop it from getting too hot, is there one there?
    yer thought bout that but it also happens first thing in the morning
    Dave
    its the starter solenoid. dodgy connection in your starter circuit causing a voltage drop.
    you need to put a relay in the circuit, use the original starter solenoid trigger wire (on the startermotor itself) as the trigger for the new relay, and switch it straight to the battery.
    - Blaise Pascal
    yer mine doesnt have a relay so mite wire one in, im gona check for voltage drop tomorow
    the battery is outa my mates 4age sprinter so should be ok
    cheers mate
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    i am having the exact same problem right now and am fitting a new starter tomoz so ill let ya know how it goes.
    ps i have a relay in my wiring so its not that
    mereki.
    ~KEEP DRIFTING FUN~
    yer that would be good get back to me tmorow cheers bud
    Tim?
    Wild West
    Is your battery holding a charge? Maybe there is a problem with alternator? Just search the forum and google to see if you can dig up some ideas. Good luck with it though.
    edit: fkn super same time replies!
    Senior Member haydenz's Avatar
    Hayden
    Geelong
    I've been having the same problem, only after I had been driving it for a while, then trying to turn it back on, would just click over. My relay cable from the battery to the starter motor was cooked, new one is like $25. I replaced my battery terminals aswell just to be safe. Had no problems since.
    Mereki
    Badassville
    hey bud, put another starter motor and cable in and so far seems to work will let know know if theres any troubles in a couple of days, but should work fine now
    mereki.
    ~KEEP DRIFTING FUN~
  1. 4age no spark... Help wiring issue I believe
    By ecko in forum Technical - Questions
    Last Post: 3rd May 2012, 10:35 PM
  2. Weird 4age timing issue
    By bennyq in forum Technical - Questions
    Last Post: 14th November 2011, 08:01 PM
  3. 4age bigport timing issue
    Last Post: 3rd September 2011, 10:39 PM
  4. 4AGE odd idle issue
    By JinxD in forum Technical - Questions
    Last Post: 18th August 2009, 07:21 PM
  5. 4age starting prob
    By sprinter86 in forum Technical - Questions
    Last Post: 8th July 2006, 04:44 PM
