Random stuff I have at home. Home is Newcastle area, NSW.
Datsun wing mirrors, these are copies and are actually (from memory) B210 ones that i adapted to fit. I've filed the base plate to fit the 200B guards and i've filed the stalk a little bit to allow enough movement to the mirror head so you can use them with a 200B.
The head is a bit loose currently, you can get to the underside of it and do up a nut which puts more preload on the internal spring though, i'd advise doing that before install.
They bolt straight up into the standard spots, installation will take you literally 10 minutes, or they will fit just about any car with flattish guard tops.
Selling due to getting hold of some genuine Datsun mirrors.
After $20 + post for them.
Universal wing mirrors, pair, brand new chrome, universal fit. $100 plus post.
S14 Radiator - Thicker than an S13 and S15 radiator, easy to fit to an S13. OEM quality. $80 plus post.
CA18DET FWD version turbo manifold, $30 plus postage.
S13 catback exhaust, fairly loud, single rear cannon only. Was on my S13. Might need some minor tweaking to make fit another car (was cut and shut in the past for some reason). 3" straight through with stainless muffler. Offers around $50 pickup.
Coilover springs one pair 8kg/mm. From HSD ** coilovers but will probably fit others. $70 the pair plus post.
Personal steering wheel. Made in Italy, leather etc. $100 plus post. No boss etc.
Japanese Learner and Elderly plates. Suction cap version. $15 each delivered.
Japanese learner plate magnet $15 delivered.
PM or reply here for more info etc.
Thanks
Jarich
