Results 1 to 4 of 4
Thread: How to tell if gbox/diff is dying?
    Eastside
    Default How to tell if gbox/diff is dying?
    Car - Ae71
    motor - 4ac
    use - daily
    problem - thinking g/box and/or diff is on the way out..
    occurs/started when - all the time
    personal situation - not good..
    Hey guys,
    What are the common symptons of a dying gearbox and diff? my car has a whinig noise when driving (suspect diff) and it feels like its loose. when you take off, and then change gears it jerks forward when you let the clutch out (wheather its quickly or slowly) it feels like the diff is going to come out. but everything under there is tight. and when im in 4th or 5th and like "chatters" even if im going fast.
    when i say "chatter" i meen like say your doing 50kmph and you grab 5th and your not going fast enough? it does that at 110kmph still.
    when i put the clutch in it makes like a "squaling" noise witch i think from memory is the thrust bearing?
    thats the best i can explain it. any thoughts?
    cheers, Ben.
    Some postman, is groving... to all our love letters... some postman is gonna cry! - Some postman you turned out to be..
    Veteran shift_rook's Avatar
    SE Burbs
    yeah thrust probasbly on the way out, with the diff bring your car round to mine, we'll check all the bushes and pull the diff apart and check all the bearing, come round this weekend bro, we''l get her pretty
    Eastside
    yeah i thort it was.
    yeah i'll let you know dude. text me your mob number.
    i'm going down the shed and sort out my alignment issue's so, i'll check the uni's aswell.
    cheers, chris.
    SE Burbs
    done, let me know man
  1. [VIC3691] 1982 ke70 wagon + a dying 4ac
    By Casey-G in forum Cars for Sale (Toyota Only)
    Last Post: 31st May 2012, 07:34 PM
  2. [VIC3691] 1982 ke70 wagon + a dying 4ac
    Last Post: 28th May 2012, 12:57 PM
  3. 4ac is dying
    By khai2298 in forum Technical - Questions
    Last Post: 12th July 2010, 06:15 PM
  4. Dying waterpump?
    By ae86 slide in forum Technical - Questions
    Last Post: 21st June 2009, 12:40 PM
  5. 4age keeps dying
    By Skin in forum Technical - Questions
    Last Post: 13th May 2008, 10:18 AM
