Sweet thanks for that, my switch failed on me the other night and had to drive home with the high beams on.
ok ive posted when i had issues with mine this and last week and i found a tonne of info some helpful some for a diff prob, so ill post up afew of the solutions found so other people dont havto traul so hard.
For all your guys out there driving without your speedo, and more importantly your tacho, at night.
Got mine working nicely a while ago, so good luck.
- Warm up soldering iron.
- Remove top part of dash. Don't forget the nuts on the wiper and lights switches.
- Take out lights switch.
- Pull apart the switch and pull out the little circuit board at the back.
- Re-solder all the connections on this board. Don't add wires or change the connections, just add a bit of new solder and make sure all the connections are good.
- Put back in and check it works, then blame me if it doesn't.
Ok, this is how i got to the switch, and is the most explanatory way.
1. Take of the Wiper and Light Switch knobs.
2. Undo the nut on the Wiper and Light Switch's.
3. Under neath the dash, where the instruments are there are 3 screws.. undo these.
4. To the Bottom left of the steering column there will be 2 screws, one for the instrument
black dash and another for abit of interior, undo both of these.
5. To the Bottom right of the steering column there will be another 2 screws, one for the
speaker cover and another for the instrument black dash.
6. Undo the Speaker cover first to get to the 2nd screw, you will then have to put your
head under and you will see the screw hidden away, remove this.
7. Undo the wheel lock, drop the wheel.
8. Remove the Instrument Dash Black Cover, move it as far back as possible.
9. Unplug the cable to the demystify on the back hatch window.
10. Proceed to remove the switch, once remove, unplug that as well.
Soldering, propping time.
11. Take apart the bottom white plastic bit, there will be 2 clips either side, unclip them
with a small flat head screw driver.
12. You will now see the contact piece, clean it till it looks like new. A clean rag will
do fine.
13. By now you should be seeing the other side of the circuit board. Add solder or re heat
the old ones. There may be some points that have no solder (there was in my case). Get the
soldering iron and solder and put enough so it covers the whole point and gives contact.
Mix in new solder with old. You may also have to prop the circuit board up with a piece of
cardboard if it is getting contact.
14. Put the circuit board back, and clip the white plastic box back together.
Once you have done this, take the switch to the car, plug it in, and test if the dash
lights go on and off. do it as many times as you wish. the light switch should now be fixed.
15. Now reverse the steps, but before this, makes sure you put the switch in the right way.
If you find after woods its in the wrong way, you can easily remove the black dash piece
again, or leave as is for whenever your going to fix it.
I hope this helps, and gives some people a better idea of what to do.
Matt.
and what ive found that worked thanks to steroidchickens, thanks man, was that the plug that connected to the white box at the back of the switch was the problem, always loose and checked it after his advice and sure enough it came loose permanantly and cause headlight failure, tie a ziptie around the switch and plug, pull it tight, prob solved.
another thing was the contact points within the white box had baddd corrosion so open it, clean, reassemble, should work.
hope this can help people, cheers all![]()
4-ac stock sprinter.
yeh my lights cut out on a cruise in coldstream hitched a ride in a commo, when dropped off back at my car cable tied the stalk to highbeams on, sucks insanely badly.
my dash lights dont work, the adjustor thingy doesnt do anything since last week![]()
Pull the switch out, and cut the two exposed wires.
Solder them together, then may aswel do the whole process in this thread aswel!
Presto
How the fuck do you take off the switch :/ do you just keep twisting it or what?
does this also apply to the wipers module?...im guessing so...
my wipers don't work - although that could be due to 1 of 2 things (i can think of)
1. switch is old - needs some tlc (as above)
2. wiper motors are gone needs replacing
any recomendations/advice is appreciated.
Thanks
Nick
to make it easy you need a long 17mm socket to undo the plastic nuts that hold the headlight and wiper switches onto the dash surround. To get them out first the lower dash trim needs to come off then you drop the steering column down (or take off the steering wheel) to get the dash surround off. now you can get at the switches.
anyone???
old thread but this sounds like it would fix my problem of no high beam in the high beam on position ... i get it when i pull back to flash but it just go's off when its in the forward ( on ) position
