check out the tags at the bottom of the page for this
thread - bored drunken dbag central and vaginal hemroid to name a few
hey call howd you welding your engine bay
hey cal im not really sure how its wired up.
its the loom from jays beams setup so it should be spot on wiring wise.
dont say that cowman
That coiil output bit is quite narrow, narrower than 20v, thinking it may be 3sg or something, it will still work just need to fuck around with a lead.
i meant cal how did you go welding your engine bay?????
Dont have a cow, man.
cassius, seriously dude, take a break from the car if you have to, I pulled down my 20v set up the first time, over 1 fucking sensor that was faulty, big mistake on my part. And i regret bad.
The set up ran before, it will work again, you just need to take sometime with it. Like a fine female, you can't rush these things. It will be something ridiculously simple, it will just be finding it that is the tricky part.
yeah thats the idea behind the ke70>4age
will give me abit of time to sort things out and gain some knowlage mabey?
this is actually the first time ive really ever worked on and engine as such. so im sure ive missed something
