Results 1 to 6 of 6
Thread: Oil filter mounting face measurement on block
    Todd
    Cleveland
    Default Oil filter mounting face measurement on block
    Hi
    I am at present going through the motions of ordering an Accusump and oil filter relocation kit and plumb it all in when I get my block back from the machine shop and assembled. Can someone give me a measurement of the oil filter mounting face outside diameter on the block. I guess some 4age engines have a factory sandwhich plate for the supply to the oil cooler that the filter mounts to but I need the OD measurement on the block not the sandwhich plate. I hope someone can help me out.
    Thanks in advance
    ToddW
    Moderator Sam-Q's Avatar
    Endeavour Hills
    as you want the measurement of the flat machined surface where the oil filter rubs on the block? if so I can organise that
    Todd
    Cleveland
    Yep that is the measurement I am chasing. The machined outside edge to outside edge or OD. Thanks a heap Sam Q.
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    I measure 69mm, should double check against Sam though
    Endeavour Hills
    70mm for me on a 20v and 72mm on a 7afe block. It's not perfectly round so the 69mm above could of just been from a different point
    Todd
    Cleveland
    Thanks a million fellas. That is exactly what I needed. I will order the adapter today as I was unsure of the fitment of the new adapter until now. It is a generic "Toyota" adapter which has an OD of 66mm so all should be perfect.
    Once again thanks for you help.
  1. Oil adapter - from block to oil filter
    By Low Style in forum Technical - Questions
    Last Post: 17th May 2012, 10:32 PM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
  4. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
