pm golberg on this forum, wired up my MicroLeb in my car
Hi guys, to any of you guys that have put in a lt10s, do you need the aux wires? Where do they go? Also in what order do the 4 crank angle sensor wires go? Cheers for the help guys.
dose
Crank angle wire diagrams are on the Microtech website.
What motor is it going onto?
It's going onto a 4age 16 valve with 20valve trumpets. I will pm golberg and see what he says.
Aux is for things like thermos, launch control, intercooler spray. Just things you can add if you want. I'm only using 1 for the thermos at the moment.
You don't have to use any of them if u don't need them.
Cas I can't help you on. I can have a look at mine wen I get home tho. Wouldn't u have a distributor though?? Or have u got a x4 box??
yeah i have a dizzy i have gone through the instructions again i didn't realise it was either a dizzy or crank angle sensor. thanks for the info about the Aux wires i really wasn't sure about them. i have never installed one before so im still working it out.
no prob man. i didnt wire mine so admire your willingness to give it a shot.
