Results 1 to 10 of 12
Thread: moving panhard rod mounting points
    Senior Member spoon's Avatar
    Oatlands
    Default moving panhard rod mounting points
    after lowering my ke, the car now sits just touching the bump stops, which makes it not that nice to drive... Before I cut the bump stops out, I have to do something about the panhard rod because at the moment the exhaust touches it and if I cut the bump stops itll only make the problem worse, the other thing is the diff sits over to the drivers side because of the panhard angle...
    Seems to me the easiest way to fix the problem is relocate the mounting point for the panhard rod on the diff housing to sit a bit lower as at the moment it angles upwards towards the passenger side and I want to keep the exhaust I have and also keep the panhard rod relatively horizontal.
    Is there any reason I shouldnt do it this way (as opposed to getting a panhard rod with a bend in it)
    Jonathan
    Suspension is important. Exhaust is cheap rubbish than can be changed later.
    Get the suspension right, then change the exhaust later to go around it. OK?
    Go ahead and cut your bump stops in half. But, your car is probably too low by the sounds of it. Buy some new springs and start again.
    Buy an adjustable length panhard rod. Don't worry about the angle.
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    why is your car so low? pics please
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Oatlands
    just had a better look at the car, the exhaust is definately hitting the panhard, but theres alot more room that i first thought, might just modify the exhaust after all, and make the panhard adjustable length.
ID:	8373   Click image for larger version.
    Jon
    Durack
    you can pick up adjustabke pan hard rods for about $100
    Glenn ke_70's Avatar
    Clay
    Barossa!
    my diff hits the exaust doesnt really do much just a few scratches and dents
    Gone
    Joel
    Picton
    get rid of the overdiff system, just go straight through
    Senior Member Blizzerd's Avatar
    Mike
    Thornlie
    bend it.... with a massive hammer, or get adjustable
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    AJPS make a panhard rod that suit lower hanging exhuasts.
    FTP.
    Gone
    Joel
    Picton
    your exhaust is the problem - not the panhard - your car isnt even that low - ive seen many more E7's tucking rear wheels and they have no issues.
    dont touch the panhard - just cut out the "over diff" section of the exhaust - then replace with a straight section under the diff.
    problem solved.
  1. Panhard rod
    By Lancerdup in forum Cars or Parts Wanted
    Last Post: 24th July 2012, 06:45 PM
  2. seat harness mounting points
    By aus_86 in forum Technical - Questions
    Last Post: 3rd July 2010, 01:31 AM
  3. BT air box has the same mounting points as ST box?
    By Grant #2 in forum Technical - Questions
    Last Post: 8th August 2009, 11:02 PM
  4. Harness Mounting Points
    By SON57A in forum Technical - Questions
    Last Post: 7th June 2008, 06:29 PM
  5. harness mounting points for coupe
    By Buddy in forum Technical - Questions
    Last Post: 1st May 2007, 10:46 PM
