Results 1 to 10 of 11
Thread: harnesses
    Ridgehaven
    Default harnesses
    Pretty simple
    How have guys fitted harnesses to their KE70s? As in where on rear parcel shelf? and where do the bottom brackets attach?
    4-point Sabelt items btw
    pics would be useful
    Cheers, Ben.
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    Id suggest using a harness bar of some description as the metal on the rear parcel shelf I doubt would be sufficent for harness mounting unless you use the child safety seat anchorage points.....as for the side mounts, replace the seatbelt clip bolt and the B-pillar retractor mounting bolt with proper eyelets as these places are both designed with strength in mind
    Veteran corknose's Avatar
    Callum
    rear baby seat holes? pen15 put his somewhere ask him.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Matt (pen15) bolted his to all the factory seat belt mount bolts. So he used the front bottom 2 as usual and used 2 rear seatbelt holes in the back.
    Its not ideal though because its better to have them go back to a harness bar which is higher up.
    Callum
    yeh cause if he has a big crash it will just fuck his seat up n not work,
    Lawrence
    Wollongong
    Its more so that if you have them doing down too far then it can compress your spine in a crash which might very well paralyse you.
    Gone
    Joel
    Picton
    yeah what golberg said - the ideal angle is within 10' downward of the horozontal line drawn from the driveres sholders, but you can go up to 40' angle down.
    and straps short as possible.
    Ridgehaven
    So I'm getting a (half) cage made up soon, get a some sort of mounts on this yes?
    Veteran Touge Boy's Avatar
    Modbury
    Any cage builder worth his salt should be able to build a legal harness bar.
    And yes, get one put in.
    Ridgehaven
    yeah I'll be getting one from Jay when I can
  1. OMP 4Point Racing Harnesses For Sale
    By greeneyes in forum Car Parts For Sale
    Last Post: 18th September 2011, 10:24 PM
  2. harnesses
    By MrMatt in forum Technical - Questions
    Last Post: 26th September 2006, 11:22 PM
  3. racing harnesses
    By ke70matt in forum Technical - Questions
    Last Post: 25th August 2006, 04:05 PM
