Results 1 to 10 of 15
Thread: turbo pretend boosting
    callum
    qld
    tully
    Default turbo pretend boosting
    Car - 86
    motor - 4agte
    use - weekend driving
    problem -turbo boosting fine (if not earlier than before) but its not putting the power down, like it makes all the same noises and that, but i dont go fast.
    occurs/started when -i was mucking around with idol/cas to sort a high idol problem, got the idol down and BAM, boost gayness happened, turned the idol back up and problem still exists. i checked all the intercooler piping and its all tight and no holes.
    personal situation - unmarried, but i have a girlfreind, saving up for a house, watching family guy atm...
    your friendly neabourhood electrition. for cash jobs pm me!
    Veteran biggo's Avatar
    Nick
    Noosa
    I dont get what you are asking. Do you have a boost guage that shows VAC/boost?
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    What did you do to your CAS.??? if your timing is off that will make it feel lazy.
    From what your say with your turbo boosting alittle earlier, it sounds like you've accedentally retarded the timing...
    get a bigger turbo. 3037's go mad. i would know....
    callum
    qld
    tully
    yesm and it reads like normal. to 15psi, however it just doesnt have the kick of a turbo. it FEELS like an intercooler hose is loose, or off. but non of them are.
    Veteran corknose's Avatar
    Callum
    check for leaks.
    Todd
    Auckland
    Auckland
    New Zealand
    sounds like timing to me, or limp mode... you didn't leave it in dianostic mode or something?
    waht computer etc?
    Jason
    Nundah
    You can't go telling ppl that...Not with out extra details..
    3037 is a BIG turbo. wheather you think their not is entirly up to you..
    I'm considering getting one for my sr in 52 trim, and that is boderline to what i would consider to still be reasonably responsive..
    And why would you want a turbo that is cappable of 400whp on a 4a anyways... you never goin to use it to its potential...
    Aaron
    In the Mountains
    maybe he was just being funny about that turbo size. you would be crazy just to go out and buy a turbo from one person saying so... but if he did he would be a right turkey lol
    check ignition and cam timing. esp ignition as you have been playing around with it. cam timing not very likely to have jumped a tooth.
    Gone
    Joel
    Picton
    What do u mean by mucking around with the idol/CAS - did u actually set the timing with a timing light? if u didnt all i can say it your gonna stuff your engine! especially critical on a turbo motor.
    you need to go back and reset what you attempted to fix, aka the timing - yes playing with the timing affects RPM but its not your solution - an adverse affect actually!
    your high idol is most commonly caused by a vacume leak.
    re set the timing with a timing light or it will be the end of your engine in no time . guarenteed, setting the timing with your ear and RPM can lead to engine failure.
  1. boosting a na bt20v
    By slider4life in forum Technical - Questions
    Last Post: 23rd August 2010, 08:15 AM
  2. GZE Supercharger randomly not boosting
    By sundee in forum Technical - Questions
    Last Post: 29th December 2008, 05:03 PM
  3. Boosting troubles
    By AE71 Rolla in forum Technical - Questions
    Last Post: 5th August 2008, 11:48 PM
  4. TRIPPLE BOOSTING
    By slydar in forum Offtopic Discussions
    Last Post: 14th July 2008, 09:42 PM
  5. 4agze not boosting
    By spaniel in forum Technical - Questions
    Last Post: 19th May 2008, 10:34 AM
