i think it needs a wash haha , list sounds pretty good , with a set of wheels would look great.
Hey guys been around for a while. this is my t18
engine specs are
self built 3tg hybrid
260 2tg head
double valve spring
reground cams unknown specs
ported head
reseated & reground valves
new valve stem seals
shaved head
all new gaskets
3tc block crank & rods
flycut 60 thou oversise 3tc pistons
fully ballanced bottom end
18rg sloex carbys
4 into 1 extractors
2.5 inch exhaust 1 muffler
electronic crane cams ignition
drive line specs
lightend flywheel
heavy duty clutch
t50
locked series 2 tseries
suspension wise
front ae86 coilovers
kyb shocks
whitline swaybars
superpro bushes
rear is just cut falcons but looking for new rear setup b4 new rego
let me know what u think regards slidekid![]()
i got the exhaust cut out the same as the intake
chris milton race engines did it cost 25 $
i used oversise mahle 3tc pistons witch were $ 185 new with rings & pins
at a guess close to 1950 or 2000
nice job dude havnt seen this car in ages from when you come to c1s with the webber on haha
still looks the same but the motor! looks good mate![]()
only just got rego again yesterday.
its been of the rd for a year and a bit i have a cressida daily now.
spent all day polishing & fixing it today & got about 50 ks of runing in done
i had it on the rd for a few days when i first built the motor &the cam gear come undone . and bent all my valves
then pulled themotor apart replaced all the valves & so far so good
Hey guys. Just an update, I now onw this car. Expect BIG THINGS at Mallala. That is all![]()
how much power is it making?
