Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: Exhaust build, over or under axle setup?
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Default Exhaust build, over or under axle setup?
    Hi guys,
    Just about to build an exhaust system for the 86. Are most people running over or under axle setups? Will be running coilovers and lowered to a reasonably low height. If the exhaust is over the axle, would the axle hit it going over bumps?
    I was thinking of running it under the axle as it would be much simplier to make... but then risk hitting the ground. Most other imports seem to run under the axle, does this also apply to sprinters?
    Any suggestions would be great.
    Jonathan
    If you make it under the axle, you just have to consider the length of your shocks, and that everything should be 100mm off the ground to be legal. I'm told it can be done.
    Timmy D
    North
    Default other imports
    yes most other imports are under diff BUT they are also indapendent rear ends where the diff does not move alowing you to put fully sick hektic drift cannons bro. eg wrx, evo, nissans ect. I am running over the diff in my sprinter
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    over diff is better as u can lower the car more
    Elite rthy's Avatar
    Leo
    Tulla
    isnt the reason why people use under diff cos the rear suspension is so low there no room to go over
    also there are some benifits with underdiff like less restriction but not sure if its legal or not to run on the streets?
    30kw club
    Vesley
    Geelong
    Yeah I figured thats the reason why the under diff setup was used, cos lowered cars had no room over the diff and not to mention much easier to fabricate. That under the diff picture looks like it's over 100mm off the ground too.
    But as you said, is it legal? Or does it simply have to be higher than 100mm off the ground as Johnny mentioned? Can anyone shed some light on this... would hate to build it and have to hack it up again.
    Veteran johl's Avatar
    Johl
    mine is under diff. the old one went over and the trailing arm mount rubbed a hole in it. the only thing that is bad about mine is that i cant drop the diff all the way down as it will hit the exhaust. no big deal tho
    Ryan
    qld
    brisbane
    Aust.
    if you an underdiff exhaust, make sure to put a flange just before the diff... as removing the whole exhaust to drop your diff is neither fun or enjoyable.
    go under the diff with a flange as seek said..
    you dont have to worry about height...as long as its close to the diff. with the diff bieng unsprung its always the same height(wheel dependant) so u can go lower with an under diff then with an over diff.
    but as jonny said... it can be bad news if you have too much droop and hit a decent bump
    Jonathan
    As far as I know, any system is legal. Does not matter if its over or under the diff. As long as it's not TOO loud, exits past the rear door, does not stick out from the car, is over 100mm, and does not sound like a bee in a can. But I havn't read any rules lately.
  1. best exhaust setup for stock bigport
    By s13 james in forum Technical - Questions
    Last Post: 17th October 2012, 08:48 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. Replies: 11
    Last Post: 3rd October 2011, 04:58 PM
  4. SWAP W5 GBOX SETUP, FOR 4ag, FOR T50 SETUP!!
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 12th August 2009, 10:46 PM
  5. Replies: 34
    Last Post: 22nd February 2008, 08:34 PM
