Results 1 to 8 of 8
Thread: Ae71 good swaybar sizes + vn swaybar
    Eastside
    Default Ae71 good swaybar sizes + vn swaybar
    Car - Ae71
    use - street/drift
    problem - good size swaybars for street
    occurs/started when - i brought a ae lol
    Hey guys,
    hoping to start ordering some suspension parts soon and wondering what is a good size front swaybar for daily/drifter? i've seen alot of guys running 24mm fronts? and a good size for rear?
    my setup should be like this:
    ae86 coilovers, xt130 arms, hoping lsd diff, cambertops, front and rear strut brraces, panhard rod, 7kg front springs and 5kg rears.
    also, is there any truth to Vn commo rear swaybars bolt into the rear?
    cheers guys, ben.
    Some postman, is groving... to all our love letters... some postman is gonna cry! - Some postman you turned out to be..
    Veteran Konakid's Avatar
    Henry
    Eastern
    Id go a rebushed stock front bar and an 18mm rear bar.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    defently get adjustable if your buying brand new
    i regret getting a fixed front bar
    Eastside
    thanks champ.
    how many mm did you go on the front? and how much of a improvement was it?
    ben.
    Clay
    Barossa!
    i bought a 24mm selby front bar fairly early on and understeered like fck. ive resently just bought an adjustable rear and feels so much better now, much more balenced. it took a few adjustments on the rear bar to get it right. so i'd doubt i would of got the right rear bar.
    which brings me to my other point if you get a front bar get a rear bar as well because it almost handles worst (i don't know about a rear bar and no front)
    Clay
    Barossa!
    this is a really good thread
    Dan
    SE
    i've got a vn rear in mine, cost like 25 from centre rd wreckers, will need 2 drill out the e7 rubber diff mounts bigger, try to drill the rubber so the sway bar is more forward as its hard to get on to begin with.
    and yes its quite bigger compared to the e7 one
    Aaron
    In the Mountains
    just a rear ADJUSTABLE will be fine for drifting. will help the car to hold the slide for longer.
    id prob keep standard swaybars for street grip driving.
  1. Standard swaybar sizes ke70/86
    By munki in forum Technical - Questions
    Last Post: 5th March 2014, 08:55 PM
  2. Rear swaybar D bush bracket and rear swaybar linkages
    By jakel in forum Cars or Parts Wanted
    Last Post: 8th July 2012, 11:19 AM
  3. Swaybar sizes?
    By markiitourerv in forum General Topics (No Technical Questions)
    Last Post: 10th August 2006, 10:53 PM
