i have 6's in the back of my keto with kyb's its still bumpy it all really comes down to how bad the roads are where u drive, but alot of people do recommend 6 in the front n 4.5 in the back for daily use
Hey guys, I'm running AJPS 8kg front springs and 6kg rears with (new) KYB excel G shocks and the car is bouncy as. The dampers arnt good enough to controll the springs. So I have 2 options I guess:
Softer springs- would these shocks control 6kg fronts and 4.5kg rears?
Or better shocks, which I assume will cost a lot more than a new set of springs, and prehaps the 8kg/6kg combo is too stiff for street use anyways.
I've only driven it up and down the driveway at this point! Lol, but over the bump into the shed it bounces and if you jounce the car by hand its like the shocks are stuffed... It keeps shaking for a bit
Need AGX adjustables or softer springs.
Bloody hell i thought i would never see people on here admitting that 8/6kg is too heavy a spring rate for the street. Was only a little while ago that AE86 owners would scream blue murder if you ran less.
im running s13 setup with 10kg fronts and ksport coilovers rear 4kg and feesl too twitchy. but now i got 6kg on the front and to suit 4kg rears it feels really good, abit of body roll abit buts its ok, i like it![]()
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
before jumping to conclusions - take the car for a good drive - usless this driveway you have is huggee
I run the same setup as yours, and in no way does my girl 'bounce'. Double check and tighten everything, and like sundee86 said, take it for a good drive!
86's for over 10 yrs...
i had 8 and 6 with short stroke kyb excel g's and when going super hard over sizable bumps the shocks couldnt keep up. Car was quite low tho.
