hey guys got a few random items laying around the house i need to get rid of
1. set of 20valve injectors unknown condition ( recommend clean & flow test to be safe) $50
2. Standard sprinter adm drivers side seat one tear on left hand side i think comes with rail that is in perfect working order $50
3.20valve rear main seal part number 90311-70007 $25
4. Rear seats and rear seat belts out of sprinter missing both belt buckles for floor seats in very good condition $50
5. Kenwood amp KAC-8404 specs listed below brand new never used brought 2months ago $200 RRP=$350
Maximum Power Output
600W
Rated Power Output (14.4V )
50W x 4 at 4ohms (20-20kHz 0.08%THD)
75W x 4 at 2ohms (1kHz 0.8% THD)
180W x 2 at Bridged 4ohms (1kHz 0.8%THD)
General Features
Compact Chassis Size
Aluminum Die Cast Heat Sink
Class AB Amplifier Circuit
Power MOS-FET Switching Power Supply
Speaker Level Input
Signal Sening Turn-On
Bass Boost f=40Hz Gain 0 - 18dB (only Bch)
2ohms Load Capability
Blue Illumination
Gold Plated Power & Speaker Terminal
Cooling Fan
Built-in Variable Low-pass Filter 50-200Hz (12dB/oct)
Built-in Variable High-pass Filter 50-200Hz (12dB/oct)
Size: W 280.0mm x H 59.0mm x D 238.0mm
can post australia wide 1,3,5 located in sydney for pick up for items 2,4
