Results 1 to 10 of 11
Thread: [VIC] WTB: Front damper inserts and single threaded sleeve for jig
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    Default [VIC] WTB: Front damper inserts
    for a 51mm strut...
    just wanna start with second hand adjustable shox for making coil-overs. prob getting these new now but bumping one more time.
    Gone
    Joel
    Picton
    just head down to your local steel supplier or engineering shop, 51mm ID is a pretty common size they tell me.
    just get an off cut.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I got an ae92 TRD yellow shock here that I don't need.
    Its stuffed, cracked case. Yours for postage cost.
    Zac
    Sunnybanku
    ah no thnx, need working shox
    Zac
    Sunnybanku
    good point ill just do that...
    still after shox
    Zac
    Sunnybanku
    bump....
    Zac
    Sunnybanku
    bump.........
    Gone
    Joel
    Picton
    if u dont mind me asking - what did you need the used shock/insert for?
    Zac
    Sunnybanku
    making coil-overs - but friend of mine says agx are great so ill roll with them i think... unless some good nick TRD's or tokiko something like that turns up i might go that way instead.
    Zac
    Sunnybanku
    also i hear agx have a very high rebound over bump which will work well with my setup
  1. Replies: 4
    Last Post: 10th January 2012, 07:37 AM
  2. AE86 front springs + inserts
    Last Post: 17th September 2011, 09:34 PM
  3. Where to weld HSD threaded sleeve onto XT130 strut casing?
    By Plelz in forum Technical - Questions
    Last Post: 6th October 2010, 08:38 AM
  4. Tokico Kg/mm Front damper info?
    By Sparkle86 in forum Technical - Questions
    Last Post: 27th January 2008, 04:46 PM
  5. Front strut inserts
    By Óli ae86 in forum General Topics (No Technical Questions)
    Last Post: 5th January 2008, 12:02 PM
