Results 1 to 6 of 6
Thread: ae86 struts ae71 stearing arms?
    Timmy D
    North
    Default ae86 struts ae71 stearing arms?
    Car - AE71
    use - street
    problem - trying to fit AE86 struts and the stearing arms will not locate in
    occurs/started when - changing over the Ae71 struts to AE86 item
    personal situation -
    Im trying to put the AE86 struts into a stock AE71, the two locating bushes in the stearing arms for the bottom 2 bolts just will not mate up to the struts.
    are they compatable?
    i have tried so many different ways and i can only get one bolt in and the other one just will not line up.
    i measured the AE71 bushes and they are 102mm spacing and the struts are only 100mm? are they suposed to crush a little when fitted? i would have thought 2mm was a bit much?
    any help would be great
    JJ
    Senior Member resol's Avatar
    steve
    vic
    yeh mate, they are not compatable, you will need some ae86 arms (corona fit but they are loooooooong). even stock ae86 arms will be fine, chuck some spacers in the rack for some more lock while your doing it too (if your chasing more lock that is ).
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Timmy D
    North
    danm it i was afraid that was the answer
    nar not after more lock at the moment just want the ae86 stuts and brakes in
    cheers mate
    JJ
    Kieran
    corona are easy enough to find but.
    svenmate has a way round it that he is using on his at the moment which involves grinding and a smaller bolt bit dodgy though...
    Mark
    i'd just go and grab a pair of xt130 control arms with the steering arms still on them. That would be the least work and thats what im all about hahaha
    Senior Member spoon's Avatar
    Oatlands
    I have some corona arms if ya want? where are you?
  1. Ae86 stearing arms (Perth)
    By jmorley in forum Car Parts For Sale
    Last Post: 8th February 2011, 07:03 PM
  2. Replies: 11
    Last Post: 3rd December 2010, 05:44 PM
  3. AE86 Stock front arms/struts
    By Jusdrifn 86 in forum Cars or Parts Wanted
    Last Post: 25th June 2009, 11:06 PM
  4. AE86 Steering arms onto XT130 struts
    By sr_rolla in forum Technical - Questions
    Last Post: 24th September 2008, 10:07 PM
  5. stearing rack into stearing coloum
    By sherlock in forum Technical - Questions
    Last Post: 1st April 2006, 06:49 PM
