put a block of wood under your gas pedal and dont drive like a arse bandit lolz
Hey guys
looking for a rev limiter as i need to run in my new motor and i cant afford a computer at the moment and I dont want to accidentally blow the motor if I over rev!
In Sydney but I can pay for postage
^ lol
baha could possibly work but its doing my head in having to constantly stare at my speedo to make sure i dont go over 4k
your speedo displays RPM?
get a 5" tacho with shift light and mount it in your line of sight... then you dont have to look down. haha
what says you cant rev passed 4k ... id say dont go passed 5k but mainly just dont sit on the same rpm for to long ... eg. freeway driving lets say 110km is 3000rpm slow down a lil till it reaches 2500rpm then drive like that for 5 min then speed back up to 3000rpm for 5 min or so ... the run in is only 1000km ... that should be about 2-3 weeks of driving depending on how far you go to work each day ... and weekend driving ... id say save your money and bear it out ... also a tip when you come to a hill put it in a higher gear so that it slightly labors the motor ... not so much that it is hard to drive but enough so you can put your foot to the floor and you wont gain / loose speed ... it will force the piston rings out and helps the run in.
Wap...wap..............wap...............wap
You should be able to feel when the engine is around 4k?
If you can't, I don't think you should be running it in?
I really want one of these.. Soooo coool.
thinking about one for my SR.. and setting it at like 6500 so i can just ride the thing all day. so used to driving corollas when you always keep it WOT while sliding
