You should be able to feel when the engine is around 4k?
If you can't, I don't think you should be running it in?
I really want one of these.. Soooo coool.
thinking about one for my SR.. and setting it at like 6500 so i can just ride the thing all day. so used to driving corollas when you always keep it WOT while sliding
Dont worry about it so much. If you go over 4k a few times you wont damage your engine.
email jessy streeter i got one a while back from japan for about $120
the dyno pull to 300rwkw
do it on the cheap side ... like it was mentioned above ... get a block of wood under ya pedal ... just get a mate to measure the distance to the floor when its at 4k then cut the wood to size and drill a few holes threw it close to the pedal and throw some cable ties threw it ... when your done running it in cut the cable ties off and your all good ... and no money down.
and what happens when he gets to a hill and wants to keep it in a labour the motor?
let him work it out...![]()
i dont think its good or nessesary to drive so crazy that you would miss shift....
if miss shifting is such a problem for you then perhaps you should convert to automatic.
